View Full Version : C3110 Losing Sttings when turned off
Gaffers01
05-23-2019, 12:47 PM
We have a c3110 that when its turned off and then on again,
it asks to enter the date and time etc back in.
i know very little about these machines but presume there some battery that's gone bad somewhere?
Bix
05-23-2019, 03:49 PM
Hi, if the plug is not disconnected, maybe the settings remain.
However it is a CR2032 battery that you find by removing the rear center cover.
copier tech
05-23-2019, 06:46 PM
I had the exact same issue, updating the fw did the trick.
However it didnt loose the network settings or address book literally only the date & time so not a big deal. Dont shut machine off at main switch use control panel sleep button.
rrrohan
05-25-2019, 03:03 AM
I recall firmware patched this issue.
Gaffers01
05-28-2019, 03:02 PM
Hi thanks for your help i updated the firmware and problem disappeared. ;)
