CopierNerd
05-23-2019, 05:06 PM
Greetings!
Machine is bizhub 654e. Total Copies/Prints produced is only 10K. First the error code was c-9401 which is related to CCD and Lamp. Lamp is turning ON. Tried to reset it several times but all in vain. Then i opened and checked CCD unit. Checked all connectors then turn it ON.
Now the error code changed to C6753. I read thread of "Blackcat" about this error right from customer premises. Then opened ADF and checked timing belt sensor. It was OK. Reset it but nothing happened.same code. Then i disabled DSDF. Removed all connectors and cable but DSPIB was plugged on the main board. Then this error c6753 again showed. This was weird for me.As i had unset the DSDF from Service mode.
Then i removed the Dual Scan Image processor board from the MFPB. Error gone. Machine got ready. I made copies and it was all clear. Then i checked all the connectors and reseatted them again. as a result this damn error code c6753 again occurred. Don not know why. Then some times it give c-9401 and most of the time c-6753.
I am confused which part is faulty? Its the wiring or DS cable or even DSPIB board? What happened to CCD unit? why these 2 codes are appearing one by one ?
Please suggest any solution or at least point out the faulty part so that i can replace it. I cannot take boards and cables with me to swap them for troubleshooting. SO.......
Many Thanks
Many Thanks
