View Full Version : Bizhub c280 transfer belt advice please
MrKis
05-24-2019, 12:33 AM
One of my clients has a C280 that has just popped up with a transfer belt needs replacing soon warning.
Roughly how many prints before it hits the life stop?
Can the belt be changed with generic stuff or is a complete unit the best idea (£250+).
Not sure if the ITB has been reset before or not.
copyman
05-24-2019, 12:38 AM
Not sure how long but it's a good while. But it can be set to not stop if not set that way already.
There are 2 options, replace just the fuse to reset (or "new release" in service mode, not sure if this model had it yet) or rebuild with aftermarket kit (belt, cl bld & fuse if used)
I've had good results with both options and saved a lot of money while customer saved a lot. If contract customer I would just reset, if charge customer sell them rebuilt.
Actually 3 options if you want to include a new OEM belt.
Hansoon
05-24-2019, 07:14 AM
Contract customer; provided the prints are OK, reset by doing "New Release".
For others we get after market belt. If you get the complete belt unit, not only the belt + cleaning blade, you better remove all paper separator fingers. Had once a brandnew after market belt that crashed cause the finger in the middle plowed through the belt.
Hans
MrKis
05-24-2019, 10:20 PM
Thanks for the advice, this is not a contract customer and I think this unit may have been reset before.
Can anyone suggest a good source for the rebuuild kit or the parts
(belt, cl bld & fuse)?
Olivetti A0EDR71600 is the original ITB
I think I can see just the belt on Ebay for £150 outside of the UK.
Can't find ITB for sensible money, genuine Olivetti/KM or generic.
JR2ALTA
05-25-2019, 12:20 AM
If it's not a contract customer they pay ultimately, with a markup. Why worry?
rrrohan
05-25-2019, 03:15 AM
Why not wait until it fails? Sounds like your trying to save them money by only rebuilding.
copyman
05-25-2019, 01:37 PM
It's not always about saving the customer $$$ but there is much more profit for the company selling them the rebuilt belt. It's a win-win customer saves money and you make a nice profit. Everyone's happy. There isn't much room to make $$ with OEM.
By the way I never use aftermarket toner or developer in ANY color copier or printer no matter how much $$ it will save. I do use aftermarket toner in B&W copiers & printers.
MrKis
05-25-2019, 09:14 PM
Yes I'd like to save them a bit of money and make a profit, there's nothing in it for me if I buy the OEM unit really. In that case I would do a reset and wait till it fails.
However, if you have any suggestions for where to get a rebuild kit or the parts, please comment below, thanks.
MrKis
06-12-2019, 04:07 PM
Hello again. Good news is the copier is still working.
I've been on site today for another issue and with closer inspection it seems that the unit actually reporting that the transfer roller needs replacing soon.
Looking at the life limit section below, I can see that most of the black consumables have already been reset.
I'm going to look for a new developer, because I have a faint print out that I'm sure is down to the developer unit. Everything else I will leave alone until more issues arise I think. Is the reset procedure for the roller the same as for the transfer belt? Will the roller cause a print stop?
Consumables
Toner
Status
Yellow
42%
Magenta
72%
Cyan
54%
Black
44%
Drum Unit
Status
Start Date
End of Life Forecast.
Cyan
89%
11/1/2012
12/5/2020
Magenta
89%
11/1/2012
12/5/2020
Yellow
89%
11/1/2012
12/5/2020
Black
100%
19/7/2017
6/11/2018
Developing Unit
Status
Start Date
Cyan
55%
11/1/2012
6/7/2025
Magenta
55%
11/1/2012
6/7/2025
Yellow
55%
11/1/2012
6/7/2025
Black
100%
11/1/2012
1/11/2017
Consumables
Status
Start Date
Ozone Filter
100%
10/6/2015
18/2/2019
Fusing Unit
93%
21/3/2014
3/11/2019
Image Transfer Belt Unit
100%
21/3/2014
8/5/2017
Transfer Roller Unit
100%
10/6/2015
18/2/2019
Waste Toner Box
Ready
copyman
06-12-2019, 11:07 PM
Looking at those life counts not sure why you need to replace or reset anything? Also unless you or someone already reset the consumables you shouldn't be getting a faint print with those counts.
Makes it harder to troubleshoot when life counters have been reset, unless you keep good track of what you reset and write in machine log (the log I always forget to fill out for the last 40 yrs!)
You can reset the transfer roller message in service mode, life, "clear" count.
MrKis
06-13-2019, 11:10 AM
Thanks for the reply, I'm pretty sure the ones at 100% have already been reset. I have not reset anything before on this printer and some of the end of life forcasts are years old, so I'm guessing that they were reset at some point close to the end of life forcast date.
