Minolta bizhub 223 repair
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5000
    Hi there,
    Have Minolta bizhub 223. Next week, I'll be changing the developer and drum.do I have to do something in the service mode after that? (Don't have SM)
    Thanks.
    Z
    Canon tech
  • tsbservice
    Field tech
    • 7923
    Re: Minolta bizhub 223 repair
    You have to clear some counters and run Stabilization+ Gradations.
    PM me if need manual.
    • zoraldinho
      • Mar 2008
      • 5000
      I will. Thank you in advance!
      • pinspin
        • Oct 2011
        • 156
        Execute TCR Sensor Adj -
        SP / Image Proc Adj /
        TCR Sensor Adj / Black / Copy
        • tsbservice
          Field tech
          • 7923
          Ahh, almost forgot the most important thing
          PM sent.
          • Toxic
            • 694
            I do first drum dry from admin menu
            Probably it does not have important role but done that everytime on this series like manual says, old habit.
            • srvctec
              Former KM Senior Tech
              • Oct 2009
              • 827
              Same here. It just gets the cleaning unit cleaned out so when you remove the drum unit, toner doesn't go all over the place from the tube connecting to the developing unit. Works quite well, in that regard.
              Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
