View Full Version : km 4500i doc feed jams
jper34
05-30-2019, 07:58 PM
Hi Folks,
I have a Kyocera KM4500I series the document feeder jams intermittently, after the last sheet comes out of the feeder. Most times, it works fine..but when it acts up..any suggestions, the rollers and belt, seem fine..I've cleaned all the sensors, rollers, so forth..I can show up, and run the heck out of it..it will work fine..Thanks, in advance for any input !!
Jaime
I.C.S.
Ropariva
05-30-2019, 08:49 PM
Does it jam because it is trying to pickup/ feed paper that is no longer in the RADF tray? There was a change to the shape of the “paper in” sensor some years ago due to the lever hanging.
JR2ALTA
05-30-2019, 09:18 PM
There's a one-way in the back that causes two-sided jams with one sheet just about exited like you describe.
Otherwise I've had 1mil+ on ADF that needed all the convey rollers replaced due to narrowing.
blackcat4866
05-31-2019, 12:02 AM
If they're J9000 jams, I'll agree with Ropariva. The original detection flag does a little bounce as it drops from the last original, detecting a phantom original. On a few machines I added a torsion spring to damp the bounce. Do I have a photo? Yes:
42712
Oops ... that's Amber running off with my socks.
There it is:
4271442713
jper34
05-31-2019, 12:29 AM
42712
There it is:
4271442713
Black Kat,
cute cat...but you may be right, it doesnt matter if it is double sided, happens on single sided copies, too...that darn cat !!
I'll check tomorrow for that flag bouncing..I'll let you guys know, what I find..Jaime
blackcat4866
05-31-2019, 01:13 AM
The way I caught this was by removing the outer skin of the top door, then running just single pages. You can see the flag operate. It only uses gravity as a return. =^..^=
