View Full Version : Error Code Konica Minolta 1052
lmblmb
06-02-2019, 12:31 AM
I am getting a code c-2811 when I try to run the service setup for a new rum and developer. When I try and run the step Charge Potential adjustment in faults out with Error 3 and then throws the code. I have changed the Charge wires, Cleaning blades, TPS sensor and the DPS sensor .Nothing The machine will come on but when you try to print the pages are blank. Ant suggestions?
Synthohol
06-02-2019, 04:03 AM
blow out your aidc/potential sensors around the drum. probably toner blocking the lens.
Drum potential sensor
(DPS) data abnormality.
While in the drum potential
correction, no
convergence is obtained
even after correction is
made more than 10 times.
When this condition is
detected 5 times in
succession, the error code
is displayed.
blackcat4866
06-02-2019, 01:36 PM
Is the drum rotating?
I had AC power cause this on a 950. =^..^=
