View Full Version : Accurio C6085 print quality issues
Robert @ JG
06-04-2019, 08:17 PM
Our department recently acquired a behemoth Accurio C6085, and it's a fine, speedy machine, but the main purpose of its use is to print on large-format paper and cardboard (13" x 30") in the LCT tray. So far, it has printed well if we use lighter paper in the 1/2/3 trays, (106 to 135 g/m2) but when we use thicker stocks (200 to 300 g/m2), we notice a light haze/dusting of black on the open white spaces, as if the cardboard is dirty… (It isn’t) and also some banding in 2-sided prints, especially in dark area on the backside of prints, the cardboard used was Supreme Silk 12pt cover. Those Issues happen mostly with the long-format prints in 26" to 28". They seem less severe on 12x18 and 13x19 stock.
Then we have tried Enviro100, and it resulted in rather grungy, inconsistent solids. We would need to decrease the glossiness of the printed ink in order to attenuate the inconsistencies caused by the rough texture in the saturated areas. Is there a fuser speed, a temperature setting or a magic tweak that could accomplish this?
Thank you for suggesting some setting tweaks to avoid those problematic issues.
Robert in Montreal
methogod
06-16-2019, 03:55 AM
photos of prints? on long sheets as well as 12x18 or 11x17. looking for repeater marks...
life of consumables?
imi1953imi
09-29-2019, 07:46 AM
Hi.....There
What about the fusing temperature adjustment when you printing on think paper..??? try that.
Thanks...
imi1953imi
10-03-2019, 10:48 AM
Robert in Montreal
Hi there all
we have the same model c6085 with print counter around 1041257,we replaced drum set KMCY,DEVELOPER SET KMCY,
first transfer rollers,MCY,transfer belt and done the associated adjustments.
The problem is that after running few prints random codes,c-4641,4642,4643,4644 are thrown I/O PUT tests for shutter and shutter motor home position sensor tests passed ok.....any help????
Regards
