View Full Version : Jamming Paper jam
mayorg
06-11-2019, 01:42 PM
I have a problem with my konica minolta c258 showing misfeed detected. Remove paper as indicated by circle code 14. Have cheack every were I can find any paper in side machine please help me out
Sent from my SM-N950U using Tapatalk
Synthohol
06-11-2019, 02:36 PM
Try to open and close every door.
What is the actual jam code?xx-xx?
mayorg
06-11-2019, 02:38 PM
14
mayorg
06-11-2019, 02:39 PM
I mean code 14
mayorg
06-11-2019, 02:42 PM
What is the actual jam code?xx-xx?It show code 14
emujo2
Try looking in the duplex section..If you truly do not see any paper here, then you may have a torn piece of paper blocking an actuator, or a non working sensor. There are 2 sections of the side door, one hides the turnover (duplex) area.
mayorg
06-11-2019, 02:47 PM
Try looking in the duplex section..If you truly do not see any paper here, then you may have a torn piece of paper blocking an actuator, or a non working sensor. There are 2 sections of the side door, one hides the turnover (duplex) area.How can I get the duplex sensor
emujo2
06-11-2019, 02:56 PM
This forum isn't designed to help an end user dig into a MFP to find broken sensors. If you do not see a piece of paper in this section and you are still showing a jam 14 then call a tech.
mayorg
06-11-2019, 03:01 PM
This forum isn't designed to help an end user dig into a MFP to find broken sensors. If you do not see a piece of paper in this section and you are still showing a jam 14 then call a tech.Am also a technician this is my first time I across this code
emujo2
06-11-2019, 03:12 PM
Then you must be the least trained tech I've ever heard of..This isn't even a trouble code..It's a jam code meant to direct the operator where to look for a jam. If you, as a tech, cannot determine if it's a torn piece of paper, a bad sensor, or paper still remaining in the paper path then you probably should be taking phone calls and sending tickets out to trained techs..
srvctec
06-11-2019, 03:20 PM
Exactly what I was going to say!
Synthohol
06-11-2019, 04:25 PM
14 is not a jam code. It's a location.
Jam codes are "j##-##"
Look in the jam history if it's not displayed
