View Full Version : FS 534 SD BIZHUB C224
jaime cruz barron
06-11-2019, 05:05 PM
Hello i need to know if i can place a finisher fs-534sd of a bizhub c224e equipment in a bizhub c368 / 308 equipment
thank any comment.
Phil B.
06-11-2019, 05:25 PM
thank any comment.
that should be covered in the Sm.
tsbservice
06-11-2019, 05:35 PM
Yes.
thank any comment.
And yes, you are lucky today ;)
emujo2
06-11-2019, 07:06 PM
thank any comment.
I'm not so sure..the combo FS534 and SD-511 are shown as the same for the 224e and the C368, but the C368 cannot use the relay unit that comes with the older 224e..The C368 now needs the RU-513..Not sure if the older finisher boards support this.
tech51
06-11-2019, 07:14 PM
I think you may run into firmware issues as well.
copier addict
06-11-2019, 08:33 PM
I have used the FS534 from a 4 series with the relay unit on an 8 series several times without any problems. I have updated firmware and the machine takes it just fine.
jaime cruz barron
06-11-2019, 09:03 PM
Thank you very much for the contribution.
You could tell me what firmware version you used.
copier addict
06-11-2019, 09:14 PM
Well, if you are installing the finisher on a C368 series machine you would install C368 series firmware.
tech51
06-12-2019, 02:30 PM
Ok you’re correct.
Just for for future reference though if you fit one to a C458, it won’t work....
