View Full Version : Taskalfa M5550ci Fax Trans speed and WSD
iscott
06-14-2019, 09:48 PM
Any one know if you can change the Fax transmission speed from the Command Center on a 5550ci?
If so how?
Also I could not locate the Area in which to disable WSD Print. If someone could point me in the right direction for this one too I would appreciate it.
FYI when you open up the Command Center it looks like all the other Kyoceras I have but when you go into systems settings it is completely different.
Thanks in advance
Phil B.
06-14-2019, 10:08 PM
If so how?
Thanks in advance
WSD is the driver that WINDOWS installs.. redo install, sending ONLY the 5550ci driver to control it.
if you are a tech you should find the procedure in the SM for changing transmission speed...
what is the speed now.. and WHAT do you plan on changing it too? IS it on a VOIP line?
Santander
06-15-2019, 12:54 AM
If so how?
Thanks in advance
Both settings are available when you login as administrator. Fax speed is function defaults fax and WSD is in network protocol.
