View Full Version : Bizhub c3851 prints Red/Blue when using auto color on black and white document
captainrva
06-19-2019, 05:07 PM
When black and white documents are printed using the auto color feature, it used to print greyscale but now this machine is printing a greyscale document with blue on the left and right with red in the middle. If you make a copy from the glass using auto color of a black n white document, it will be fine but when you print the document, this weird color effect happens. Any ideas?
42906
copier tech
06-19-2019, 07:29 PM
What do the gradation test prints in CE mode look like?
What driver are you using?
captainrva
06-19-2019, 07:47 PM
The gradation prints said the values were all in range and the driver is PCL 11.1.2.0. I re installed the driver and tested the post script as well.
qbert69
06-19-2019, 08:33 PM
The gradation prints said the values were all in range and the driver is PCL 11.1.2.0. I re installed the driver and tested the post script as well.Check in the model specific driver for this machine to see if there is a sensitivity adjustment for the auto color...come to think of it, that setting might be in pagescope!!! Anyway, the sensitivity will bias it to either be more sensitive to b&w or color![emoji41][emoji1303] In Pagescope, the auto color setting should be under the print section.
Sent from my SM-N950U1 using Tapatalk
Albonline
06-20-2019, 04:47 PM
get the driver removal tool from konica website.
allan
06-20-2019, 05:58 PM
The document seem to be scan in color mode so its a color document. The scanner could have been wonky...
If you manual select grey scale from the driver does it print correctly.
blackcat4866
06-20-2019, 06:15 PM
Agreed. Does this affect other documents? =^..^=
Albonline
06-20-2019, 08:51 PM
from what i read here there is a problem printing gray scale docs .copies are fine ,this says rip or driver. driver most likely.
captainrva
06-21-2019, 01:45 PM
The document is a PDF sent to customer and probably was scanned from another machine using full color but when I print it to another machine using auto-color, it prints fine (black and white) but when I print to the C3851, it prints blue and red. Also, if I print in greyscale, it prints in greyscale.
