View Full Version : Miscellaneous Custom Paper Size 12x12
PaperCut
06-20-2019, 03:07 AM
C368 Costume paper size 12x12,
I have restaurant account that use a thick card 12x12 paper, is there any Engine FW Switch, for this? Or they can't use this kink of size.
It jamming, after a 1st page.
tsbservice
06-20-2019, 11:50 AM
You should check product specification.
Tray 2 and bypass are your options.
blackcat4866
06-20-2019, 12:20 PM
I'm pretty sure the C368 can do 12" wide, you'll just have to set up a custom paper size. I'll check later on if the is a standard paper designation that you might select (if it appears on your list). =^..^=
srvctec
06-20-2019, 02:56 PM
From the User Quick Start Guide, tray 2 will accept max paper size 12 1/4" x 18".
Synaux
06-22-2019, 06:33 AM
If custom size does not work from bypass, print on a standard 12" stock (probably 12x18) tell the customer that they need to take it to a print shop and have it cut for a few bucks (if a large run) ;)
mincopier
06-22-2019, 01:01 PM
Since tray 2 can take 12 1/4 size width you should be able to program that size into the machine under "Custom Paper". Keep in mind that you must also tell the print driver that is is customer size paper and what size it is. Does take some playing around but it should do it.
