View Full Version : Minolta c5500ci error code - c3300
kuby
06-24-2019, 10:55 PM
Customer called and said their C5500ci has a error code of c3300. Never worked on a c5500ci. What does this error code refer to? fuser.
Synthohol
06-24-2019, 11:19 PM
a 5500ci is kyocera.
kuby
06-24-2019, 11:57 PM
Have to call the customer. They said it was a Konica Minolta.
blackcat4866
06-25-2019, 12:19 AM
AFAIK there is no bizhub C5500ci. This model looks like the combination of a Kyocera TASKALFA 5500i, a TASKALFA 500ci, and a bizhub C550. I think your customer is confused, and you'll need to use your own eyes to identify the model. =^..^=
Synthohol
06-25-2019, 02:45 AM
or google the first 7 digits of the serial number.
thats my cheat ;)
kuby
06-25-2019, 01:47 PM
Maybe a Konica Minolta Bizhub Pro C5500?
kuby
06-25-2019, 07:14 PM
WOW, customer was not close.
Copystar CS 500ci. How do you get Konica Minolta out of Copystar?
Synthohol
06-25-2019, 10:22 PM
C3300
Optical system (AGC) problem
After AGC, correct input is not obtained
at CCD.
Poor contact in the
connector termi
nals.
Check the connection of connector YC5 on
the ISM PWB and the connector on the
inverter PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
Defective exposure
lamp or inverter
PWB.
Replace the exposure lamp or inverter
PWB.
Defective PWB.
Replace the ISM PWB, ISC PWB or CCD
PWB and check for correct operation.
Code
Contents
Remarks
Causes
Check procedures/corrective measures
https://wallpapercave.com/wp/wp2559443.jpg
kuby
06-25-2019, 10:34 PM
Gotta love customers. Getting more of the story. This guy came around selling this copier and the customer I guess bought it. She said he had it in a van with the copier on ITS SIDE. What dumb a$$ puts a copier on its side. You get what you pay for.
blackcat4866
06-26-2019, 12:42 AM
Hows that for guessing? Were I to guess I would say that:
1) your scanner is probably bent
2) your CCD may be bad
3) your scanner control board may be bad.
Since this machine is already obsolete, my best advice is to consider it a total loss and just dispose of it.
If the scanner is bent, you probably won't be able to straighten it out, or spend a week fiddling with it, and still not have it work quite right.
If the CCD is bad ... and you find one ... you'll still need the calibration test patterns to calibrate.
If the scanner control board is bad ... and you can find one ... you'll still the calibration test patterns to calibrate.
I really don't see how this can go well for you or for your customer. That's me: Mr. Cheery. =^..^=
