View Full Version : I-Option question
Kenny
06-25-2019, 06:36 AM
Hi guys,
We have recently installed I-Option LK-110 document converter on a Konica Minolta C364e at a customers so they can scan to Word, Excel and PowerPoint. Do we need another I-Option for them to be able to edit the text in that scanned document? Originally thought you would be able to with just this I-Option or are we missing something?
Any help would be appreciated!:confused::confused::confused:
B0265
06-25-2019, 08:46 AM
Make sure that you select "text priority" in the character recognition settings.
The quality of the OCR function in the LK-110 isn't very good, but that is my personal opinion.
Kenny
06-25-2019, 10:29 AM
B0265,
Are they then able to adjust the text in the scanned document?
B0265
06-25-2019, 11:06 AM
Yes, if you for example select "docx" as the file format you can open the scanned file in Word and edit the text.
Kenny
06-25-2019, 12:50 PM
B0265,
I am currently onsite now, the scan sends over as an image and you are not able to edit the text on the document? am I missing something?
B0265
06-25-2019, 01:00 PM
Have you set character recognition = "on" after you selected DOCX as the file format?
Kenny
06-25-2019, 01:25 PM
It was not there at first but when I installed the OCR dictionary it then appeared but all I get is preparing OCR dictionary startup and doesn’t scan. I believe I need an LK105 for this to work?
emujo2
06-25-2019, 01:30 PM
From the C458 spec guide...Generates various file formats incl. DOCX, XLSX and combines LK-102 (encrypted PDF) + LK-105 (searchable PDF/OCR functionality)..Does not specifically say editable , and only lists PDF as OCR/Searchable. You are looking at the ability to create text searchable OOXML files.
Kenny
06-25-2019, 01:39 PM
Guys I seem to have sorted the issue. Downloaded certain types of firmware for the OCR dictionary and PDF/A font and worked!!!!
Appreciate the help any way guys
emujo2
06-25-2019, 01:50 PM
So now you have "text editable" word docs??
Kenny
06-25-2019, 02:50 PM
Yes:D
jwai
08-29-2019, 02:05 PM
It means, installed LK110v2 and updated firmware for it, as the result have Word file which can be edited?
BTW, the i series is not necessary to add extended memory for i-option, not like the 4e and 8 series?
