View Full Version : C6500 color registration assy sensor C-4521 error
joaodaffonsojr
07-02-2019, 01:13 PM
Hi !
I need to replace this sensor !
But i don't want to buy the role color registration assy.
It's possible to know the part number only for the sensor?
Thanks !
430364303743038
tulintron
07-02-2019, 01:49 PM
Hi !
Thanks !
430364303743038This set has only one code.
No parts found
tulintron
07-02-2019, 01:52 PM
[QUOTE = joaodaffonsojr; 780065] Oi!
Eu preciso substituir esse sensor!
Mas eu não quero comprar o assy de registro de núcleos de função.
É possível saber o número da ação apenas para o sensor?
Obrigado!
430364303743038[/ QUOTE] Porem, observe que está no Brasil. Talvez poder te ajudar. Estou em Minas Gerais.
lucky13
07-05-2019, 05:14 PM
i dont see a part number for that sensor looks like all in 1 unit what you can do is take the tiny clear cover off the front of the sensor and blow the dust out and switch it with the other one they are the same see if you get a different code , also how many prints on the trans belt and internal rollers ? developer and drum counts as well .
these dip switches will temporally get the machine running till you get sensors sorted out
25-5=1 color reg less percise for speed
will disable color reg adjust till you get sensors, reg may suffer
25-3=1
25-4=0
