View Full Version : bizhub c3351 intermittent error c-2155
POPEYE
07-09-2019, 01:47 PM
Got a service call, c3351 when switch from b/w to color print ,after color print out sometimes show c-2155. service manual said :transfer belt contact fault after k pressure established,,already replaced transfer belt ,1st transfer pressure solenoid SD-1,1st transfer pressure sensor ps9,but cannot fix the problem.any suggestion ?thanks alot
Bix
07-09-2019, 01:54 PM
Hi, have you tried/changed the M1 motor?
POPEYE
07-09-2019, 01:58 PM
thanks for reply ,already ordered M1 and will be replaced soon,but I test M1 in service mode -load check mode ,it will turn ,so i think M1 seems normal
CraigW
07-09-2019, 02:14 PM
My boss did battle with a C3351, having 2155 under warr.
He did M1 with no luck.
The last thing on the list was..... "main drive assy"
POPEYE
07-09-2019, 02:19 PM
thanks for reply!so replaced main drive can fix it?
CraigW
07-09-2019, 02:23 PM
That was last item replaced.... no calls / or 2155 codes since then.
POPEYE
07-09-2019, 02:34 PM
Thanks alot,I will bring along main motor and main drive assy ,hope its not MFB.
CraigW
07-09-2019, 02:44 PM
^^^^ He did that as well.... right before he did main drive assy
tech51
07-09-2019, 07:03 PM
Definitely the drive unit. We have had two examples of this in the last couple of months. Drive unit fixed it both times.
Georger@kmdirect.co.za
02-04-2020, 12:09 PM
Hi Popeye,
Please advise if you managed to solve this errer with the main drive and advise if is possible to strip and change main drives at client site. Tha ks
POPEYE
02-04-2020, 01:39 PM
Hi Popeye,
YES,the main drive solved the problem
and I changed it at client office,the table had enough space for me to service.
