View Full Version : Miscellaneous Moving & Disassembling Bizhub C280
skukan
07-10-2019, 02:14 AM
Hi. I have a Konica Minolta Bizhub C280 that needs to get into a basement space. Unfortunately the door jam to the basement is about 1 inch shy of getting the machine through. Does anyone have experience with moving a Bizhub in pieces? I am not an "official" tech so this would be new to me. Any help and support is greatly appreciated. Scott
blackcat4866
07-10-2019, 03:00 AM
You may be able to reduce the width by a single 1" by removing external covers. If that doesn't work the door frame will have to be removed (I know ... easier said than done). The metal copier frame is going to be the minimum width that you can get. =^..^=
allan
07-10-2019, 06:23 AM
Remove the screen or else the entire side door. Like BC said its a solid metal frame.
