View Full Version : Miscellaneous Konica C1060L Bizhub Image problem Issue
fakhritraders
07-11-2019, 10:20 AM
Hello
Need to resolve this problem, if anyone knows how to solve this problem, I have Konica C1060L, Machine Counter 500K recently replace all 4 drums, developer, transfer belt & blade, charging corona, all OEM, did Glass scan calibration, don't have an external Fiery, now the problem is images are printing darker, & halftone screen are not visible from 3%-15%, on picture, image density becomes dark. Density measurements setting are on 0. Thanks43098
Toxic
07-11-2019, 02:52 PM
After replacing this parts i only do toner density sensor init,blade setting mode,color registration auto adj., and auto gamma adjustment and so far no problems.
How you do calibration from glass?
fakhritraders
07-11-2019, 03:08 PM
Thankyou for reply, I have not done blade setting, i will do that, calibration done with Scanner glass with print from printer gamma offset auto.
fakhritraders
07-11-2019, 03:22 PM
Perform all this steps again, but nothing happens still same result.
blackcat4866
07-12-2019, 01:16 AM
Are you using aftermarket toner? =^..^=
fakhritraders
07-12-2019, 01:46 PM
Thanks for reply, Toner we purchased is from Konica local Distributor, many service options has been done from service manuals, but problem is still same.
raplma
07-12-2019, 02:08 PM
I confess to not knowing the c1060L, so ignore if not applicable. but check it's colour registration assembly.
We had a c6501 and several c451's that used to do do this and in both cases it was the colour registration sensors, or IDC sensor.
Took them out, gave them a good clean, making sure the gate springs are connected, the sensors are clean and in the case of the c6501 the felt pads were cleaned.
We also have a c5501 and c7000 which both have the same set-up but of course the c1060 being the next generation this may have all changed.
seximibabay07
11-25-2021, 11:17 AM
pls: Any one for share the Konica C1060L Bizhub Service Manual???
Synthohol
11-25-2021, 01:24 PM
normally i would hound you to become a contributor but its thanksgiving here and im feeling generous.
ck your PMs :)
seximibabay07
11-25-2021, 02:18 PM
ck your PMs :)
god bless U...
lucky13
11-29-2021, 02:50 AM
have you tried resetting max densities all to factory {recall standard data factory} then re-adjust
