View Full Version : Bizhub C451 w/ EK-603
Dave10
10-13-2008, 02:37 PM
Techs,
Does anyone have any experience with the EK-603 USB Interface? We have several issues, so bare with me. First, we installed 2 EK-603 into 2 Bizhub C451 machines. When we tried to insert USB memory sticks into the interface, we got no recognition of the external memory the way the instructions said we should. This was our first experience with the EK-603, so we are unsure whether we need to initialize the unit in some way. Does anyone know if we do and if so, how? Also, as a warning to others, nowhere in the literature does it say not to use a drive with U3 software installed. Evidently, it will corrupt the machine firmware. Which brings me to our next problem.
Our 128mb compact flash will not load the firmware.The message says "Invalid Card". We have tried to use the ISW interface to load firmware, but we keep getting various errors. Does anyone have DETAILED information on how to use the interface and which filenames to use?
Last question, we were led to believe the EK-603 had replaced the EK-602 and can be used in the C451. Is this true, or do we need the EK-602?
Any help would be appreciated as this is an emergency.
Thanks.
pepper38_cnd
10-13-2008, 03:21 PM
Did you create the card using the Firmware Imaging Tool?
Dave10
10-13-2008, 03:25 PM
Yes. We used the firmware imaging program. I am led to believe the firmwrae of the machine can be corrupted by the U3 software on some USB drives so we are trying to reload it, but can't. That is why we want to try the ISW method.
pepper38_cnd
10-13-2008, 03:59 PM
If you are referring to the Internet ISW upgrade procedure, from what I can see you would have to have a fully functional machine connected to a server. If your machine is not fully functional then rewriting firmware with a CF card is your only option. What exactly is your machine doing? And have you removed the Ek-603 putting the machine back to the condition before you started?
konisolver
10-13-2008, 04:15 PM
The problem is with your cf card - I would recommend to get a new card and reflash it. Now about your usb kit - the u3 software does not corrupt the firmware it will just not work and you will get a message on the copier screen that there are two devices attached to the unit for which it will not work. Google U3 remover and you will get a link for a U3 removal program which is free. This will format your thumbdrive and you will be able to use it with your machine. Good luck.
Dave10
10-13-2008, 10:07 PM
The machine is working perfectly but won't recognize the flash drive when it is plugged into the EK-603. We have removed both units (we have 2) and tried them in other machines. Nothing works. I would still like info on the ISW method of loading firmware. Which file do we indicate in the machine interface and how should it be formatted?
pepper38_cnd
10-13-2008, 10:12 PM
This may help it's form the service guide.
dogsbody
10-14-2008, 08:25 AM
don't buy cheap ones, we went through several brands before getting a couple of sandisk cards, they work every time.
strider5555
10-15-2008, 08:49 PM
The problem you have is because you are using the wrong USB interface kit. The kit for the Bizhub C451/550/650 is the EK 602 and the product # is A090WW0. You are using an EK 603 which is made for the C203/253/353. It won't work! Get the correct interface kit, update the firmware, and you should be good.
pepper38_cnd
10-15-2008, 10:39 PM
According the the Copier Reference Chart released by KonicaMinolta Oct2008
Ek-602 for models C451,C550,C65
EK-603 for models C203.C253,C353,C451,C550,C650
Is this a mistake in the reference chart.
Dave10
10-16-2008, 02:19 PM
According to Konica-Minolta and NEC( who sells the machine under their brand), the 603 IS compatible with the 45. It is a later model that replaced the 602.
Dave10
10-16-2008, 02:23 PM
According to the Konica-Minolta site and the NEC site ( they sell this machine under their brand) the 603 is a newer model and replaced the 602. It is supposed to be compatible with the 45C4. I confirmed this with NEC and they confirmed with K-M.
leo
10-17-2008, 10:30 AM
603 in c451 works in norway.
maybe your software is too old
