View Full Version : Lexmark MX711de's with ADF misfeed issues
Jtech
07-12-2019, 05:54 PM
I have a few Lexmark MX711's that experience ADF misfeeds. The paper will stop on first page on the separator roller.
I have replaced all feed rollers and the ADF PCBA's with the same issues.
Has anyone else experienced this?
Jeff
sales@thetonerkings.com
redzventures
08-08-2019, 06:31 AM
Hi, not quite sure what exactly you mean. Does it feed at all or is it intermittent? Never had that exact problem but there should be a clutch of some sort to the Sep roller but if that fails it would usually cause double feeding. If not then drive to the feed roller would seem a place to look. You say you’ve changed boards and rollers? Not sure if there are clutches in the roller assembly. Did you change only rollers or the assembly?
