View Full Version : Fiery X3eTY2 65C-KM Scan to FTP set up
joe.m1989
07-15-2019, 10:54 PM
So I'm having some hell trying to get this person's scanner back up and running. I'd like to get it set up to scan via FTP, and I would like to ideally use the konica's FTP utility. When I go to set up scanning, it wants the file path, and under the manual, its just showing "input a file path of the FTP server." Well, the konica's ftp utility does that for me. Do I still need to specify the path without it? Because without the path, its not working. Below is a link to the manual in which is shows vaguely what to put in for the file path. Fiery X3eTY2 65C-KM User Manual (Page 52 of 101) (https://www.manualslib.com/manual/1158670/Fiery-X3ety2-65c-Km.html?page=52#manual)
Scan to SMB isn't working for some reason, but I chocked it up to typical Windows 10 and not being friendly with SMB
Synthohol
07-16-2019, 01:57 AM
just scan to the fiery HDD and the users can download the scans from the fiery webpage.
you can even add a 2nd HDD make share folders and map the drive to users.
just RDC into the fiery and set it all up. 10 minutes work really.
copier addict
07-16-2019, 01:37 PM
Anytime I have set up FTP scanning I have simply used a forward slash / as the file path
