View Full Version : C558 Tray 3 jam and noise
Hi guys,
I have a C558 that sometimes jam on tray 3, and strange noise while feeding on that tray.
I tried to replace the rollers, one way bearings and driving motor of that tray however the issue still stay.
Any suggestions for this case?
copier addict
07-26-2019, 04:18 PM
Hi guys,
Jam code?
Paper size?
Paper orientation?
Is it an LCT or universal tray?
kingarthur
07-26-2019, 04:30 PM
I had one that the shaft that the DFPV roller sits on was actually bent slightly
Jam code?
Paper size?
Paper orientation?
It's A4 crosswise , and there is PC-215 ( 4 universal trays ).
You said the shaft of double feed prevention roller, is A161-5634-00?
Jam code?
Paper size?
Paper orientation?
Jam code is 20-02.
blackcat4866
08-08-2019, 01:09 PM
bizhub 658e with PC-415, J9901 and J20-02 (http://www.copytechnet.com/forums/konica-minolta/134475-bizhub-658e-pc-415-j9901-j20-02-a.html)
How about this? =^..^=
Thank you for your information, let's try it!
I tried to exchanged the gears unit with tray 4, the problem seems be solved !
