View Full Version : Error Code How are you? I have a Bizhub c284eShow on screen serial number must be entered contac
mhmds102466
07-28-2019, 10:12 AM
serial number must be entered contact your service representaive
I need a file firmware ​konica-c284e
copier tech
07-28-2019, 12:13 PM
What work did you do prior to getting this message?
Synthohol
07-28-2019, 01:46 PM
maybe start by entering the serial number?
mhmds102466
07-29-2019, 08:03 AM
[QUOTE = copier tech؛ 788843] ما العمل الذي قمت به قبل الحصول على هذه الرسالة؟
[/اقتبس]
NVRAM has cleared the A145FW file to clear the service manual:عيون لفة:
mhmds102466
07-29-2019, 08:05 AM
After entering the serial number, the code c-D010 appears again
Synthohol
07-29-2019, 12:22 PM
format the HDD.
mhmds102466
07-31-2019, 08:45 AM
how are you
Lines are red and blue when copying only and printing is very good not showing these lines
What do I do in lines to remove?
Please, please?
I can not find the serial number for my scanner because I did not put it into the system
Enter the printer and the ADf device only
dave w
07-31-2019, 09:11 AM
Go through the setup process again, This is done when you power on the copier the first time from the factory
good luck
Synthohol
07-31-2019, 01:18 PM
how are you
Please, please?
scanner serial# is on a label under the front scanner cover, remove and you will find it.
Toxic
07-31-2019, 08:20 PM
Background
Several reports regarding “please enter serial number” have been escalated in the Japanese and European market.
Symptom
After main power on, device starts with error message “please enter serial number “. Most of the data are cleared except consumable counters.
Cause
The Battery for the NVRAM on the MFPB is empty
TAEU1801592EN_After main power on all data lost_1.3.pdf
GHV-M1 will partially solve this problem.
Woxner
08-01-2019, 12:53 AM
you dont need scanner serial or adf just enter machine. in service mode when you see the key board on the right enter stop 1144 c then enter time zone leave at 00. then touch enter then touch date enter date the hit apply then end. this can happen if you also replace ssd and mfp at same time.
Woxner
08-01-2019, 12:56 AM
by the way if print a config page it might read generic c28 6e soft sw will need to be set
mhmds102466
08-01-2019, 08:08 AM
I applied the method and still
lines
When the copy is present
mhmds102466
08-01-2019, 08:47 AM
Is it possible for a line to appear when copying is caused by an Animation Guide Data ???:confused:
allan
08-01-2019, 09:48 AM
No, just follow the install guide step by step.
gpais70
07-14-2020, 02:26 PM
The fault comes because of this. The battery missed or demaged.
Regards
Germano Paishttps://uploads.tapatalk-cdn.com/20200714/288bd7667f35e7b300b397f15f225ab3.jpg
Enviado do meu ALE-L21 através do Tapatalk
jaylex234
01-24-2022, 03:10 PM
Mine is bizhub C360 same message pls how can i solve it
tsbservice
01-24-2022, 03:18 PM
Start your own thread. Different models. Describe what you've done so far.
Good luck.
Phil B.
01-24-2022, 04:44 PM
Mine is bizhub C360 same message pls how can i solve itDead thread.
Different model
Don't be a grave robber.
Phil B.
01-24-2022, 05:54 PM
good luckLines of shame.
Go back to square one and initiate the machine properly.
