View Full Version : Error Code Bizhub 367 , code C-E301
pinspin
08-03-2019, 09:42 AM
Hi, our copier 367 , when scanning to the folder ONLY in the Сompact PDF mode 300 dpi gives the code C-E301. In all other modes, the scan is excellent! Reset copier, firmware update, replacing the HDD did not help. We will be grateful for any advice. Thank.
tsbservice
08-03-2019, 09:54 AM
Definitely sounds FW related, as with every major FW release they(KM) claiming some type of C-E301 error fixed.
First I would try it directly from my laptop to exclude any network related issues.
tsbservice
08-04-2019, 10:50 AM
Latest special firmware ver. GP2-W4 resolves more than 10 instances of dreaded C-E301.
I would give it a try if not at that FW level.
kingarthur
08-05-2019, 08:48 AM
agree latest FW, but if you look at the management list, it tells you why the C-E301 code occurs, then look at the read me file for the FW, it will tell you which C-E301 (sub code) it fixes, I've started to compile a list of C-E301 errors from the FW read me list
