View Full Version : Failed to start. Bizhub 423
escalante
08-07-2019, 10:13 PM
good afternoon. I have the following message in a Bizhub 423. I have already formatted and replaced the hard disk. also replace the DIMM memory. Please any suggestions
https://uploads.tapatalk-cdn.com/20190807/5ab6f73be945f3911be8cc857d0ceeed.jpg
Enviado desde mi SM-J701M mediante Tapatalk
Synthohol
08-07-2019, 11:12 PM
how did you format the HDD if that message comes up?
escalante
08-07-2019, 11:50 PM
how did you format the HDD if that message comes up?Before that message appeared on the machine screen, it froze and did not obey, I had to turn the machine off and on again to make it work.
The actions I did are:
1.- Format HDD
a) physical format
b) logical format
Then replace it and finally disable it.
Also replace the DIMM memory.
Please can you help me.
Synthohol
08-08-2019, 12:06 AM
Problem
"Failed to start. Please power down the main switch." message.
Solution
PROBABLE CAUSES:
1. Possible FK-508 Fax Kit failure or the Fax Kit is not installed and the MFP is incorrectly configured.
Verify the presence of a Fax Kit. Ensure that, if there is no Fax Kit installed, the machine settings are correctly configured.
Service ModeaSystem 2aOption Board StatusaFax (Circuit 1 or 2)aUnset.
If an installed Fax Kit has failed, please replace it as necessary (Item #A22M011). Reboot machine.
2. The machine is equipped with a Fax Kit and an Hard Disk Drive (HDD). The HDD is not enabled or properly formatted.
Enable the HDD (HD-516):
a. Enter the Service Mode and select System 2.
b. Select HDD and select "Installed".
c. Once the hard drive is enabled, access State Confirmation and select "Memory/HDD Adj."
d. Next, select HDD Format and perform the Logical Format.
e. Reboot the machine.
3. Bad connection between the FK-508 Fax Kit and the Overall Control Board (OACB).
Reseat the USB cable between the fax option and the OACB.
copier tech
08-08-2019, 06:52 AM
Does the machine accept a firmware update?
escalante
08-11-2019, 08:40 PM
Good afternoon. Tell him that the fax card was removed just like the hard drive. I loaded the NVRAM reset firmware. And the equipment is working perfectly. Thank you all for your help.
Thank you.
Atte. Escalante
