View Full Version : Firmware 224E Mono required please
Coggers
08-19-2019, 12:21 PM
Hi Everyone
We are a Olivetti dealer and have a Konica 224e (mono) machine that requires the latest firmware to enable airprint
We have firmware for the colour versions as we sold these but olivetti never took up the mono range
Hope someone can help
coggers
rrrohan
08-19-2019, 01:30 PM
Hi Everyone
coggers
What version you on currently. Putting it on version 7 might be enough to enable it
tsbservice
08-19-2019, 02:49 PM
You may consider becoming Contributor to this site. More than likely there will be members here who can send you desired Firmware.
blazebusiness
08-19-2019, 03:34 PM
Hi Everyone
coggers
Someone here correct me if I'm wrong but I believe the current version firmware is Model: bizhub 554e Series
MFP firmware Ver. G20-K9
If the firmware on the copier is recent enough (from Gxx-J6 or later) ......You may just need to set the software switch 25 to 60 to enable the version 7.
[Service Mode] -> [System 2] -> [Software Switch Setting]
Then, the airprint option will show up under network settings.
If the current firmware version is really old....you may indeed need the firmware. A guy on copytechnet sells it....we have used him several times. Firmware Update - Printer & Copier Firmware (http://www.copierfirmware.co.uk)
To check the current version just go to utility>device information
Synthohol
08-20-2019, 12:07 AM
554e latest FW is G20-M1 10/31/2016
copier tech
08-20-2019, 07:58 AM
There was a fw release in March this year.
43404
Synthohol
08-20-2019, 12:36 PM
that is special FW to address a tri-fold issue, not base.
its still 2016 base FW with an added patch.
tsbservice
08-20-2019, 03:59 PM
AirPrint | KONICA MINOLTA (https://www.biz.konicaminolta.com/solutions/airprint/index.html)
Which is from 31.08.2016
Which in turn means that Synthohol is right and latest base FW G20-M1 10/31/2016 should be OK with AirPrint.
copier tech
08-20-2019, 08:28 PM
There have been multiple firmware releases since the last mass production version in 2016.
These releases address various know issues but may not be necessary to enable AirPrint.
