CopierNerd
09-03-2019, 06:06 PM
bizhub c454,
JAM Code is 99-01.
Read the manual.
There is little info about it. Checked all the things mentioned. According to manual its about paper size error or incorrect paper size/type.
Total Counter : 270K
Paper jam in fusing section at number 11. I have checked the actuator of exit senor and cleaned the sensor if there is any dirt on it. But still error is there. Some times does not jam at all. 500 prints no jam. 50 prints no jam. some times jam after 8 or 10 prints. Jamming is intermittent and random.
Did not check any clutch but cleaned rollers. Same jam code from every tray. I have read old threads about this code. DIP switch 145, Hex assignment :00002.
No error about paper size. Original size selected in driver interface is 8.5x11, output size is A4. Paper loaded in trays are A4. Strange this machine does not give any error about matching paper size unless paper type is changed from plain to any other.
I am wondering if its from registration sensor or its actuator?
any suggestions?
JAM Code is 99-01.
Read the manual.
any suggestions?
