View Full Version : CQ ( 2 X ) Bizhub C754e - GREYSCALES --> CYAN !!!! ????
LAURENT19
09-09-2019, 06:27 PM
hello
recently, i've 2 copiers at the same time with the same Quality Default.
When I print Demo Page with the little bird, ---->> Greyscales are Cyan.
When I print Gradation Adjust Patern in SERVICE MODE ---->> Greyscales are Cyan too.
Firmware : G20-M0
1st copier 600 000 BW prints 180 000 Colour Prints
2nd copier 250 000 BW prints 400 000 Colour Prints
I've changed :
UI-711C
UI-711M
UI-711J
UI-711BK
and the Transfert Belt
But no result.
ID Cells ??
Laser unit ??
Thanks for your reply
Toxic
09-09-2019, 09:37 PM
Somebody put cyan toner in place of black toner?
First thing come to my mind though i never seen that on the field. :)
mo0651
09-09-2019, 09:46 PM
Have you pulled out the Black Developer unit and looked at it? make a black only copy, what do you see?
Phil B.
09-09-2019, 10:05 PM
what are you trying to print?
does it have ANY color on the page * in formatted file * ? ( if so it may be in "composite color mode"
Woxner
09-10-2019, 01:09 AM
the feet does not matter. only printer. if you change all i/u's and it did it right away then it seems electronic. dont think laser is culprit.
allan
09-10-2019, 09:44 AM
I have :D. Some of the generic toner bottles are not slotted so they can work on other models so they fit anywhere..
Will put money on that you are right.
OP please let us know.
Replaced the IU you say. Did it work OK for a bit?
mo0651
09-10-2019, 02:28 PM
You can change the Black drum all day, and problem won't change. The Developer unit is separate.:cool:
Toxic
09-10-2019, 09:00 PM
You are right,CMY is imaging units but black is separate DR/DV :)
allan
09-11-2019, 05:39 AM
Post an image of the gray gradations please.
Walterj
09-12-2019, 08:51 AM
hello
Firmware : G20-M0
I've changed :
UI-711C
UI-711M
UI-711J
UI-711BK
But no result.
ID Cells ??
Laser unit ??
good day
Dear I recommend you check the black developing unit and the HV1 / HV2 / HV3 boards
Greetings
LAURENT19
09-13-2019, 05:39 AM
Thanks Walter,
I think we are on the GOOD WAY ---> the HV1 / HV2 / HV3 boards
I tried JUST to :
- Unplugged the UI-711 Cyan
- Reinsert the UI-711 Cyan
All is GOOD :confused: ( HOW LONG ..........)
I try this SOLUCE on 1 copier
Perhaps CONNECTORS of HV :confused:
Walterj
09-13-2019, 08:11 AM
Thanks Walter,
I tried JUST to :
good day
Dear
If I help you, I think you should isolate the sockets and measure the continuity of the wiring that goes to the HV boards.
Regards
Luck
