View Full Version : Bizhub c3850fs airprint button missing?
mrfuser
09-12-2019, 09:34 PM
anyone know the trick to turn on airprint? I have upgraded to the latest firmware and it still does not show up.
Thanks all!
K
copyrooks
09-12-2019, 09:47 PM
CAUSE: Incorrect software switch settings
SOLUTION: Perform the following procedure:
1. Enter Service Mode
2. Select System 2
3. Select Software Switch Settings
4. Select Sw 13
5. Change setting to HEX 04, press OK and select Fix
6. Cycle the power on the machine and now the AirPrint button should be available to select
mrfuser
09-12-2019, 09:59 PM
Yep been there done that. Still no AirPrint button.
2. Select System 2
4. Select Sw 13
mincopier
09-12-2019, 10:38 PM
Firmware 30G0-515 or later Dipswitch 168 needs to be set to Hex 00 to Enable AirPrint or Hex 08 to Disable AirPrint
Firmware 30G0-607 or later AirPrint should be enabled automatically.
This is what I got from Konicaminolta's spreadsheet
mrfuser
09-12-2019, 10:50 PM
I had to upgrade controller fw one more step
rrrohan
09-13-2019, 02:00 AM
so glad the C3350i doesnt have separate firmware files to load.
