View Full Version : BIZHUB C35 13E2
sakisvas
09-23-2019, 07:08 PM
Dear friends ,
my customer has a bizhub c35, the problem is tha the machine work fine as printer but when i go to copy the machine freez ..
In the control panel write ready for copy ... calibrating.
i try to update firmware and when i reboot the machine the error code : 13E2
what can i do.
best regards
tsbservice
09-24-2019, 08:14 AM
1. Try to rewrite engine firmware.
2. Replace PRCB.
sakisvas
09-24-2019, 07:51 PM
2. Replace PRCB.
can you send me please a firmware for update with usb please?
i have this file : bizhub_C35_EngineFW_v50G0-0200-00.zip
it is correct for usb update ?
rrrohan
09-25-2019, 05:23 AM
the standard expectation before anyone will supply firmware or manuals is that you donate to the forum
https://www.copytechnet.com/forums/vbdonate.php?do=donate
once you do you will get a Contributor badge under your name, im sure once you do that we can hook you up
sakisvas
09-25-2019, 11:56 AM
can anyone help me with the firmware?
thanks
copier addict
10-17-2019, 04:56 AM
Just had this issue yesterday. There are two engine firmware versions based on the PRCB. One version has a 0 and one version has a 1. One version is 50G1 and the other is 50G0. If you use the wrong version you will get a 13E2 code.
