View Full Version : Riso RZ 220UI Code P-96-569
johngallowayiii
10-17-2008, 12:26 AM
I installed a new drum in a riso rz 220ui after completing the set up of the drum i get a P-96-569 at power on. If i enter service mode i get a d-4-560. I tried to do the set up again and also checked the information and all seems to be correct. Was wondering if anyone had ran across this before and what corrected the problem.
techathens
10-21-2008, 04:16 PM
Did you ever get an answer to your question?
johngallowayiii
10-21-2008, 11:13 PM
Not as of yet. contacted riso and have been given the normal try this and let us know routine.
cobiray
10-21-2008, 11:26 PM
I recall seeing this before, but I don't remember what I ended up doing to fix it. I had replaced the drum PCB and had that code come up after I did. Double check the correct drum size and area is set.
johngallowayiii
10-23-2008, 07:30 PM
Exchanged drum pcb and rf. problem resolved.
hi friend technician l search a service manual for risographe RZ200 if any technician have please send me that in mecanopharme@hotmail.fr thank's
bisiawoeyo
02-05-2009, 03:28 PM
I also encountered the same code while installing a new EZ 200. I am s copier tech and have got no idea about how to enter the service mode, the simulation codes and theerror codes.I will apprecciate if anyone can help send me The service manual for Riso EZ 200 .This is my email address: bisiawoeyo@yahoo.com
Yetno.0103
02-14-2009, 11:01 PM
P96-569 = Either The Print Drum Color Information or Ink Catagory Information Is Still Not Input And D04-560 = Ink Tag Is Not Detected On Ink Bottle
This Error posible Appear if you insert a diffrent type of Drum (Drum EZ-330 To EZ-230). Check that ur drum type is right. and try to Re Installing ur drum.
1. Insert Ink Catridge to drum
2. Switch on the machine and enter the test mode (Do not insert drum to the machine)
3. Insert Drum to the machine pres Reset key if error appear
3. Enter test Mode 117 and start
4. Enter test mode 890 and start (this test mode will copies the ink information eg; ink color, ink catagory, etc onto the print drum PCB
5. Enter test Mode 887 and start (this test mode will pump ink from ink bottle to print drum) and drum will rotate and one page master will clamp to the print drum, wait until ur print drum stop.
6. Switch off and on machine
If ur machine still error try to replace ur Print drum PCB to the new one.
Thanks good luck
staggeringbear
10-28-2013, 06:04 PM
How do you enter service mode to input the codes?
Just see the video I made while ago for one of my technician.
https://www.youtube.com/watch?v=MRV0g9iAV1M
