sanvicente
09-29-2019, 09:03 AM
Hi. Have a c454 with toner sticked to upper fuser roller. The image reapeated in the page.
43681
First we change brand new fuser unit... 50 prints and again the image repeated. Changed transfer roller, transfer belt, power supply, another fuser and same result.
Didnt change DV units because all four colors do the same. Came back day later and exchanged with a c364 a week ago. I didnt checked voltage. My bad on that. Now in our shop I take fuser out, cleaned, and take some prints and the c454 runs ok. I tested 7,500 full color prints and machine goes ok. The c364 is also runing ok in costumer building plugged to the same Espo surge regulator and to the same outlet.
Want to know if someone may see this issue before??
Machine was on his 15 month on rent... 450k ... original toner... original parts...
A voltage issue maybe? Humidity? A lossen cable that sits fine again in the movement from costumers to the shop?
Dont want to lease it or sell it to some body else and get the issue again, and must important, wanted to know what was the cause.
Any similar experience?? Or coments? Am i missing something?
43681
