View Full Version : CQ Kyocera 6025
Momiowilove
10-03-2019, 07:38 AM
Hello to all i have system error problem in kyocera 6025 error code 3200.
Sent from my RNE-L22 using Tapatalk
Phil B.
10-03-2019, 09:41 AM
Hello to all i have system error problem in kyocera 6025 error code 3200. Sent from my RNE-L22 using Tapatalk
10 sec Google search
Error Codes > Kyocera > FS6025MFP > Code 3200 (https://printcopy.info/?mod=erc&brand=Kyocera&model=FS6025MFP&code=3200)
H AHAHAHAHA using bias Google :cool::cool::cool::cool:
Exposure lamp problem ? cause of this error 1. Defective scanner PWB. 2.Defective exposure lamp or inverter PWB. 3.Incorrect shading position poor . 4.poor contact of the connector terminals Solutions:- 1. Replace the scanner PWB and check for correct operation. 2. Replace the exposure lamp or inverter PWB. 3.Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor. 4.Check the connection of connector YC7 on the scanner PWB, and the continuity across the connector terminals. Repair or replace if necessary.
blackcat4866
10-04-2019, 12:06 AM
Matsuri are known for Main Board failures, specifically causing C3200 errors and black copies and scans. =^..^=
JR2ALTA
10-04-2019, 01:15 AM
Could this be a simple scanner lock engaged? Or filty optics/white reference?
