View Full Version : Bizhub C35 Firmware Request
Good Day,
I am having issues getting the Bizhub C35 to send scanned emails using gmail. From what I have read, it looks like a firmware update may be the answer, eitherway, I know I am running a older version of the controller firmware.
I am currently running:
Bizhub C35 Current Firmware Versions:
Boot F/W: A12199G0050000
Controller F/W: A12130G0561505
Engine F/W: A12150G1120000
Panel F/W: A12120G0014805
Scanner F/W: A12123G0040300
Fax F/W: A12140G0012100
Synthohol
10-06-2019, 03:24 PM
ill send you a link to the latest FW on my server because you are a contributor.
this POS machine may not be able to use gmail, there are no bulletins i can see that allow the latest security measures for gmail or office365.
hang tight and check your PMs in a couple minutes.
good luck and please reply back if it does indeed work.
Just reporting back that scanning and sending through gmail is now working. I have google set to use less secure apps and the following settings on C35 web connection interface. Instead of using smtp.gmail.com, I currently replaced it with the actual IP of 74.125.20.108, I have not tried switching back to smtp.gmail.com to see if it works. I have SSL/TLS set to enabled and Port Number set to 465. SMTP Authentication set to enabled and logging in with username@domain (I would assume if your using just gmail it would be username@gmail.com) and your password. For domain name, I have my domain name set, if your using gmail, I would assume this would be gmail.com. Only other item I have set is server capacity set to 24MB as gmail only allows 25MB attachments.
Hopefully this helps someone else out.
Larsje31
10-16-2019, 08:59 AM
Is it possible to receive the firmware as well.
I have been searching for it but its quite hard to get acces to it.
Best regards,
Lars
tsbservice
10-16-2019, 10:22 AM
Best regards,
Lars
Become Contributor to this site by donating small amount of cash and sure there will be members willing to share FW.
Larsje31
10-16-2019, 10:43 AM
I have made my contribution :-)
tsbservice
10-16-2019, 11:00 AM
PM send.
Thanks for contributing!
ice007
11-06-2019, 06:30 AM
Thanks for this information, wasnt expecting anything but it worked like a charm :cool:. Great Info.
bok720
11-07-2019, 10:40 AM
Dear, I having message of missing toner cartridge in 2 units of C35. Will upgrade firmware can help to solve this issue? this error is still there regardless i change another new toner cartridge. The machine is stop and cannot working anymore.
appreciate some advice. thanks
Scrappy
04-21-2020, 11:59 PM
Would anyone mind sharing the firmware with me as well. It would be very much appreciated. Thanks in advance.
Synthohol
04-22-2020, 01:49 PM
PM sent,
thanks for contributing
synstsia
05-25-2020, 12:42 AM
PM sent,
Hello, I have just made a contribution to site also and was hoping someone could send me the latest firmware for C35.
Thank you
femaster
05-25-2020, 03:06 AM
Thank you
I'll send you a PM with a link to download the firmware files. Do you know how to install the firmware on this model? It's not that same, or as easy, as the larger MFPs. I didn't look at previous messages in this thread, so don't know if it's in a previous reply or not.
femaster
05-28-2020, 08:07 AM
Thank you
It's been 3 days since I sent you a link to the firmware, so I'm going to assume that you have gotten it by now. It would have been nice to have had some sort of confirmation or a Thank You so that I know you did in fact get it. I'll be pulling the firmware down from my cloud storage tomorrow so if you didn't grab it yet, you best get on it!
synstsia
05-28-2020, 12:22 PM
Firmware was received and thank you for your lightning fast response on it! It was much appreciated. No problem updating, just wish Konica had more substantive fixes- Was hoping they would have patched the TLS encryption version so I could use my secure email server instead of gmail with compromised settings.. with business class machines though, I guess they just assume people will re-lease newer models.
Hello,
i have a "new toy" with
Controller ROM Version A12130G01403A3
Engine ROM Version A12150G1120000
Boot ROM Version A12199G0050000
Panel ROM Version A12120G00207A3
Scanner ROM Version A12123G0040200
Fax Board ROM Version A12140G0012000
the latest FW can help me ?
- i have slow speed at SMB/USB/HDD scanning (it's taking too much....may too much time to make a .pdf)
- no scan to email
- life attention message
i know it's another .... request but please make'it one more time :D
Phil B.
06-11-2020, 06:23 PM
Hello, i have a "new toy" with. the latest FW can help me ?
*** what resolution are you scanning at? ... are you compressing the file? is it in COLOR?
- no scan to email
*** Have you setup scan to email?
*** What is the message?
you should really should have posted it in the proper technical forum.
and no IMHO firmware will not fix all problems.
do you have a service manual for this unit?
are you a trained tech?
I apologize in advance for my introduction and for my bad english
- (even at 150dpi it is slow) the resolution is 300dpi color and no is not "compact pdf" and the Ethernet Settings is set to 1000Base-T (Full) so there are no problems there. i know c35 have a 800mhz cpu and it's not "comparable" with bizhub C253...... still 5 minutes for 10 pages full of text with one color stamp.
- Have you setup scan to email ?????? - yes i have (all setting are ok... SMTP server address, port number, username, password - tested on NVR(Network Video Recorder) - test ok )
- i have the service manual for c35 unit (0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0 and i read it 19E04
- i know the firmware will not fix all the problems like a bios flash in 2000 :)
- i dont know if i am a trained tech ....i guess i'm not if i have to explain my self
next time i will try the default..."Hello, I have just made a contribution to site also and was hoping someone could send me the latest firmware for C35.
Thank you"
Sorry for the inconvenience.
tsbservice
06-11-2020, 08:42 PM
Thank you"
Hey tes, don't be discouraged.
In your case a Contributor's badge will be big Yes for members including me to help you. But here we usually have a tons of user's requests for FW without any explanation so Phil(aka Dentist) have to pull some info from the wannabes.
Sure you will get what you want.
Synthohol
06-11-2020, 08:55 PM
Thank you"
sent you a PM
Phil B.
06-11-2020, 09:04 PM
Sure you will get what you want.Yeah I usually post as the Dentist in situations such as this.
tsbservice
06-11-2020, 09:14 PM
Thanks for that as we have no mods right now. Your efforts in this manner are greatly appreciated here.
gerryroehr
11-18-2020, 11:38 AM
Can someone please send me a link for the firmware for the C35.
I have several Problems with the lock and it is not the belt.
Current machine C35:
Controller A12130G0101605
Engine A12150G1090000
Boot A12199G0050000
Panel A12120G0020705
Fax A12140G0011800
Scanner A12123G0040200
Thank you very much for your help.
Gerhard Röhr
MArcio mss
11-23-2020, 11:45 PM
Boa Noite
Estou com problema numa Bizhub C35. Ela fica com a lâmpada do scanner ligado direta, anddei pesquizando e diz que pode ser uma atualização de firmware, alguem pode me conseguir para tentar resolver este defeito.
obrigado
Phil B.
11-23-2020, 11:50 PM
Boa Noite
obrigado
how about you post in your NATIVE language AND IN ENGLISH ?
and CONTRIBUTORS always get faster service.
https://www.copytechnet.com/forums/vbdonate.php?do=donate
and please review the forum rules:
https://www.copytechnet.com/forums/misc.php?do=vsarules
Phil B.
11-23-2020, 11:53 PM
Boot A12199G0050000
Fax A12140G0011800
Gerhard Röhr
Contributors get faster service: a small $10 contribution
forum rules here:
or you can
pay way more than that for the files you need.
Remus2k
01-10-2021, 09:27 AM
Hello,
I'm the new owner of an old C35 bizhub.
I have this software version:
Engine ROM Version A12150G1110000
I understand that I need to make a contribution, but I want to know if I have an old firmware or not (older than the one present on this forum).
Thank you
Remus2k
01-10-2021, 12:46 PM
Please send me the firmware and upgrade info.
I'm getting nuts with Scan to Email.
Gmail works, but my internal server do not work, but setting are correct and verified with an email client.
FW update I hope to be the fix.
Is there anyway to check exactly what auth error the printer has with my hosted SMTP server?
Remus2k
01-10-2021, 02:00 PM
Thank you @Synthohol for providing the firmware update files for Controller, Engine and Scanner
A12130G0 - 1403A3 old
A12130G0 - 113779 new ????
Engine ROM Version
A12150G1110000 old
A12150G1120000 new
Scanner ROM Version
A12123G0040200 old
A12123G0040300 new
I have some doubts that my Controller firware was newer (?)
A reset to defaults fixed Gmail SMTP !
copier tech
01-10-2021, 10:50 PM
Boot A12199G0050000
Fax A12140G0011800
Gerhard Röhr
Happy to help drop us an email
www.copierfirmware.co.uk (http://www.copierfirmware.co.uk/)
