View Full Version : Bizhub C200 scan to SMB
lebo
10-08-2019, 04:10 PM
Hello, I can not force Scan from the Bizhub C200 through SMB to PC with Windows 10.
Any Idea ?
Login, Password, name of shared folder as well as IP adresse of PC are all set OK
PC is in Private network profile with sharing folders ON
SMB server/client ver 1.0 is "ON" on that Windows PC
There is no Antivir with firewall installed on that PC
Bizhub C200 and PC are in the same workgroup.
Scan error: EE09C7
And I am frustrated :-(
Thank you for your advices.
copyman
10-08-2019, 04:36 PM
Donít think you are going to be able to do it with that old model. Maybe only scan to email or FTP
tsbservice
10-08-2019, 06:17 PM
You can do it but have to update FW to Ver. G00-35 or later as M$ literally throw out of the Window(s) NTLMv1 authentication ;)
mikeena
10-09-2019, 06:11 AM
Also go Into the program files then go into feature and make sure smb 1.1 is not unchecked. New windows updates is disabling and setting 2.0 as default
rrrohan
10-09-2019, 08:24 AM
im told re enabling SMB1 is a bad idea
Id use the trusty old FTP instead
B0265
10-09-2019, 09:50 AM
It might be that this old model only use port 139, check that NetBIOS over Tcpip is enabled on the PC.
