View Full Version : Bizhub will start printing slowly after a few days
Hello,
I have a strange problem. I have a Bizhub C458 with FW G00-W4.
The printer receives native files from SAP and after about 10 days, it begins to print slowly. There do not seem to be problems if you print outside of the management software.
In the printer settings the priority has already been set for the production, lowered network time-out and I have deactivated spool Print jobs On HDD before RIP.
The only solution to resume printing correctly is to turn it off and then on again. Could it be a FW problem? Any experience or suggestions?
qbert69
10-15-2019, 04:36 PM
Hello,
The only solution to resume printing correctly is to turn it off and then on again. Could it be a FW problem? Any experience or suggestions?What do you mean "receive native files from SAP"?...What is SAP?[emoji848]
Sent from my SM-N950U1 using Tapatalk
SAP is a multinational company that produces management software
qbert69
10-15-2019, 11:48 PM
SAP is a multinational company that produces management softwareBased on that info, it sounds like you might need to contact SAP! Perhaps it is a data cache that is not being purged or cleared properly and thus causing slow processing or maybe somewhere the network connection is half duplex instead of full duplex or perhaps even the data stream is in a format that requires extra processing?![emoji848] I'm stumped!...but you did say that when the management software is removed from the equation the machine works just fine?![emoji848] Definitely sounds like something is glomming up somewhere!!![emoji2955]
tsbservice
10-16-2019, 07:20 AM
https://help.sap.com/doc/saphelp_nw70/7.0.31/en-US/d9/4a8eb751ea11d189570000e829fbbd/content.htm?no_cache=true
I'm afraid you will need to dig deep into this.
B0265
10-16-2019, 09:15 AM
I think this procedure was implemented to solve another problem, but it might be worth to try.
Procedure of Setting Automatic Reboot every morning
This function makes MFP reboot automatically at AM 4:00 (default) every day.
The conditions of reboot function and procedure are described below.
- Condition of reboot function
Condition 1:
Software Switch No.104 bit-0 is set.
Vender serial number is set as one of following numbers.
[10] or [11] or [12]
- 10: MFP reboots at AM 4:00
- 11: MFP reboots at AM 4:15
- 12: MFP reboots at AM 4:30
Condition 2:
Under the Condition 1 is satisfied, MFP reboots at the specified time unless it is printing, receiving fax or in sub power off mode. If the MFP is printing or receiving fax, it retries to reboot after every 30 minutes for two times. The MFP does not reboot after 1 hour.
- Procedure
1. On MFP Operation panel, enter to [Service Mode] -> [System 2] -> [Software Switch Setting]. Change the switch setting to values shown below. Then, press [Fix] button.
Switch No.104 / HEX Assignment: 01
2. On MFP Operation panel, enter to [Service Mode] -> [System 1] -> [Serial Number] -> [Vendor]. Input “10”, “11” or “12”. Press [END] button. Exit [Service Mode].
3. On MFP Operation panel, enter to [Administrator Settings] -> [System Settings] -> [Power Supply/Power Save Settings] > [Power Consumption in Sleep Mode]. Select “Disabled”. Exit [Administrator Settings].
4. Turn OFF Main Switch of MFP and ON.
tsbservice
10-16-2019, 10:19 AM
Condition 1:
Condition 2:
- Procedure
Interesting and very clever solution in this case, good info.
On a side note, do you know on what models this work?
B0265
10-16-2019, 10:50 AM
This is the information I have found:
Model FW version
bizhub C754/C654 GC1-68 or later.
bizhub C554/C454/C364/C284/224 GC1-68 or later.
bizhub 754/654 All version
bizhub C754e/C654e All version
bizhub C554e/C454e/ C364e/C284e/224e All version
bizhub 754e/654e All version
bizhub 554e/454e/364e/284e/224e All version
bizhub 287/227 All version
bizhub C658/C558/C458/C368/C308/C258 All version
bizhub C287/C227 All version
bizhub 758 All version
bizhub 558/458/368/308 All version
(ID-No. PSCSES_1900148EN / TABT1900148EN)
tsbservice
10-16-2019, 11:07 AM
Model FW version
Anyway to clear a bit your PM Folders?
The solution is concerned. Weekly timer doesn't do something like that? Also is it possible to change the time?
Thanks!
B0265
10-17-2019, 07:02 AM
I have no more information other than what is in the bulletin, and have never tried it myself. I assume that the MFP will do a full reboot, not only enter sleep mode.
B0265
10-17-2019, 07:03 AM
Done.
tsbservice
10-17-2019, 09:32 AM
Done.
The following errors occurred with your submission
B0265 has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
B0265
10-17-2019, 10:28 AM
There something strange here, I get this information even after trying to empty the inbox:
"Inbox contains 0 messages. You have 65,535 messages stored, of a total 100 allowed."
tsbservice
10-17-2019, 11:49 AM
This is so-called automatic-spam-prevention function... no just kidding :D
This is known issue, here:
https://www.copytechnet.com/forums/site-feedback-and-questions/134985-much-mail.html?134985=#post716821
And here:
https://www.copytechnet.com/forums/site-feedback-and-questions/122767-inbox-contains-0-messages-you-have-65-535-messages-stored-total-100-allowed.html?122767=#post576194
Site admin Aneurysm may have to take a look, you can post new thread in Site Feedback & Questions (https://www.copytechnet.com/forums/site-feedback-and-questions/)
Let us know.
