View Full Version : program for C353
vale24
10-19-2008, 11:07 AM
Hi,
I have a customer who has C353 and often copy Identification card on both sith. The customer ask me how to make a program to copy both sides of ID card on one side of paper witn one pasing the paper through copier. I sow C252 with same program but I don't know how do this :confused: !
Thanks!
ni311
10-19-2008, 05:46 PM
If the copier have the duplex option, just select from 'Simplex/Duplex' box on the touch screen, 1 -> 2. Put the ID card on the glass, press Start, flip the ID card, press Start again and you should get a sheet of paper printed on both sides. These basics operations are in the user manual, if you don't have it I can send it to you.
vale24
10-19-2008, 06:08 PM
I've written that I want two sides of the ID card to be on one side (the same). I know what is 1>2 but this is other function.
minimerlin
10-19-2008, 06:30 PM
Try using the COMBINE settings on the same screen as DUPLEX, set output as 2in1 then scan each side of the ID card ,on completion of scanning printout the single sheet.
vale24
10-19-2008, 07:28 PM
But than copier zooming down the original on 71 %. I want them at 100%. I've seen that on C252 (it was made like a ready function - aditional) and I am mad with rage because I don't know how to do that.
AjitN
03-23-2009, 04:10 AM
Try 2 up setting with original size A5 and copy % as 100 %.
After fist side scan, turn the ID card, scan and complete the job.
Ajitn
tec966
03-23-2009, 05:22 PM
Ajitn you're right, but probably is better set the original size to A5R.
Tec
AjitN
03-31-2009, 03:21 AM
tec 966
Yes you are correct, its my slipout not to mentioned A5R.
Ajitn
