View Full Version : 8050 error SC45-20
Rev
10-19-2008, 07:28 PM
What does this error code indicate? The fix?
ni311
10-19-2008, 08:21 PM
It is something about color registration abnormality, hope this help.
Juxta5
10-19-2008, 10:00 PM
Color registration correction results in abnormality.
Color registration marks for each color are transferred on to the transfer belt during this process. The locations are detected by the color registration sensors. This information is used to determine the "image drift" amount for each color.
Possible replacement parts:
Color Registration sensor/Front (operation side of machine) (PS8)
Color Registration sensor/Rear (non-op side) (PS9)
Worse case scenerio: Problem with Printer Control Board
Maybe someone has some methods for cleaning these sensors instead of replacing them...
laserman06
10-20-2008, 03:37 AM
Could be caused by the transfer belt walking to the front of the assy. So pull it out and check. Also, go into service mode and run halftone test pattern on all colors. Make sure sheets come out covered completely with all colors.
DaveTech
10-20-2008, 06:05 PM
Hi,
I have had this problem before sometimes that code 45-20 can be caused by other things so it be worth while turning off the color registration sensor from the dip switchs in 25 mode and see if you can get the machine to start up.
redime
10-21-2008, 01:05 AM
http://www.ogator.com/manuals/AllSolutions/Color/8050.pdf
Search in the PDF
Rev
10-22-2008, 04:59 PM
Thanks to all for advice. Once I recharged all four developers the SC45-20 went away.
