View Full Version : C364e - MFP firmware update N.G
Kenny
10-22-2019, 03:55 PM
Hi guys,
we currently have a C364e on site at a customers that wont update firmware for the MFP. Will update everything else. I have made sure the 'machine' and 'type' information is correct.
I have tried using a used MFP for testing purposes but still comes up with the N.G error when trying to update firmware. I have tried using x3 USB sticks and also tried re-downloading the firmware to rule out it being corrupted.
Will this mean that the SSD board has gone bad or?
any suggestions would be a massive help.
mo0651
10-22-2019, 05:09 PM
Just checking to see if you attempted just the MFP board by itself, by unselecting all the other FW options.:cool:
copier tech
10-22-2019, 05:11 PM
Hi guys,
Are you trying to resolve a fault by updating the firmware or is the machine functioning normally?
tsbservice
10-22-2019, 05:40 PM
Try to update with HDD disconnected from MFPB.
Kenny
10-23-2019, 07:25 AM
Yes I have tried selecting that on its on own but no avail
Kenny
10-23-2019, 07:27 AM
The machine was getting 99-01 jams and saying select the correct paper in paper tray so I wanted to update firmware before anything
Kenny
10-23-2019, 07:28 AM
I have tried that unfortunately, the machines being abit of a nightmare haha 🤣
Hi Kenny, what firmware are you trying to update? I had a similar problem with a C364e. I had to disconnect the Job Separator and oddly it worked.
Try to disconnect DF, FAX, additional trays etc.
Kenny
10-23-2019, 09:20 AM
I am trying to update it to the latest one GDL-M1 and I will give that a go. Fingers crossed it works!!
Kenny
10-23-2019, 11:45 AM
Right guys I am currently on site, I have disconnected everything and tried to update firmware but still no avail. Would that mean the SSDB has gone bad?
Synthohol
10-23-2019, 12:29 PM
why are you not using G20-M1
why special FW instead of base?
Kenny
10-23-2019, 12:39 PM
Did not know the GDL-M1 firmware was a special firmware?
its just the firmware that said it was the latest on the konica website.
Synthohol
10-23-2019, 12:57 PM
thats special FW not base.\special FW is written to solve special problems.
try the real base FW G20-M1
latest does not make it the best, use the White House as an example.
Kenny
10-23-2019, 01:05 PM
I don't suppose you have G20-M1 firmware on hand do you? cannot seem to find that firmware:confused::confused:
Synthohol
10-23-2019, 01:08 PM
link sent via PM.
thanks for being a contributor.
Kenny
10-23-2019, 01:10 PM
Actually i have managed to find it. Ill give that a go now and will let you guys know how i get on!
Please work!!
Kenny
10-23-2019, 01:32 PM
The firmware hasn't sorted the issue :( its just download N.G. all the time, i then try the firmware reset which gets rid of the error invalid external device. but as soon as you try to print ANYTHING it comes up with a C-E301 error.
do you have any more suggestion or am i going to have to order a SSDB
mo0651
10-23-2019, 02:16 PM
Have you ran self diagnostic mode?? It may give you a better clue.:cool:
43850KM had a bulletin for that problem. Follow these instructions in order and it may fix your problem. Doing this procedure has fixed a lot of weird problems with these E series machines for me. BE SURE TO EXPORT AND SAVE ALL OF YOUR IMPORTANT INFO LIKE USER CODES, SCANNING ADDRESSES, ETC. When you do these formats and data clear, it will wipe out that info.
D Colour
10-24-2019, 03:40 PM
Hi
I was having a similar problem and found this post very helpful.
Konica BH C654e reset HDD lock password issue (https://www.copytechnet.com/forums/konica-minolta/140935-konica-bh-c654e-reset-hdd-lock-password-issue.html)
You may not have the HDD Lock error, but our main issue was MFP NG. Which it seems to have fixed.
Kenny
10-24-2019, 04:35 PM
We have ordered an SSDB just in case, I will give your suggestions a try! will give an update tomorrow.
thank you all for your help!!:D
Kenny
10-25-2019, 10:26 AM
I have performed this and everything says its 'OK' :confused: trying a few other bits before replacing SSDB
Kenny
10-25-2019, 10:37 AM
Dont suppose anybody has the replacement procedure for an SSDB????
Tried other bits but not worked, going to have to replace SSDB:(
D Colour
10-25-2019, 10:47 AM
I saved this from another post on here - have you tried this?
43866
D Colour
10-25-2019, 10:51 AM
Also SSD replacement..43867
Kenny
10-25-2019, 10:52 AM
43866
Yeah that's what i have tried this morning, but machine still doesn't accept firmware
Kenny
10-25-2019, 11:10 AM
Guys,
Just a quick update. The machine now FINALLY works!!!!! after replacing the SSDB the machine finally has taken firmware and all is good:D
I appreciate all the help!!
jmaister
07-26-2021, 06:58 PM
looks like i will need one as well... love old machines. love them!!!!!
