View Full Version : sd506 LEFT STAPLE MALFORMED
methogod
10-29-2019, 03:13 AM
Did all adjustments, Swapped stapler and cincher with another unit (same issue), new staples. Left side is good, right side is off...
Any hidden adjustments? How much play should the cincher have?
Any wear items that cause play during stitching?
Dropbox - 2019-10-28 21.42.41.jpg - Simplify your life (https://www.dropbox.com/s/mcqqtnypmfwrhzq/2019-10-28%2021.42.41.jpg?dl=0)
Dropbox - 2019-10-28 21.42.36.jpg - Simplify your life (https://www.dropbox.com/s/167l08cyvj0zdt8/2019-10-28%2021.42.36.jpg?dl=0)
Phil B.
10-30-2019, 05:47 PM
43890
pretty picture
explanation of the photo or what it is supposed to mean/show?
Can you see the crack on the metal plate?
In my case was this to make problem.
43891
Phil B.
10-30-2019, 07:59 PM
43891
now see how hard that was?
just posting a picture with NO EXPLANATION is no help to anyone and gets you red CARDS like you have noticed!
methogod
10-31-2019, 06:59 AM
we swapped cincher and stapler from a parts machine, no change. Going to redo alignment over the weekend.
see what happens...
MVPunisher
11-04-2019, 06:02 PM
I battled this issue. The clincher needs adjustment. Replacing it wont help as adjustment screws are out of position. One adjustment "tilt/gap" i believe it is called....is in service manual under adjustment section...The other 2 adjustments which adjust the horizontal and vertical positioning of the clincher are actually found in the "clincher installation procedure" portion of the manual. So you will have to look in 2 places' Performing all 3 of these adjustments fixed my issue. This was done after replacing a clincher with no no luck.
