View Full Version : Bizhub Secure Quetion
larweedad
10-30-2019, 05:56 PM
How can someone prove that a copier has the bizhub secure on it? The sticker is not good enough and looking at hdd capacity is not enough for some IT people to be satisfied that it is on.
tech51
10-30-2019, 06:39 PM
When we put it on we give certificates to the relevant person which states the settings are applied and also gives a record of the applied passwords.
Other than that there’s no real way I know of proving it’s on other than showing them the settings you did on the machine.
emujo2
10-30-2019, 06:55 PM
The only way to be sure is to go into admin and try to enable the HDD lock or encryption passphrase..If it's on you will be prompted for the original 20 digit code to disable the feature. E
larweedad
10-30-2019, 07:13 PM
Thanks for the feed back
