View Full Version : AirPrint missing on C360i G00-73 Function 2
rrrohan
10-31-2019, 08:47 AM
Cant find AirPrint on function version 2
If i set it back to function version 1 the option re appears.
Mopria still available
Hi, if you enable Bonjour for some reason AirPrint will work.
I send you the function code in private
rrrohan
10-31-2019, 01:50 PM
thank you, will try when i return to work in about 12 hours. is this private? if it works cant i post it to help others?
emujo2
10-31-2019, 02:42 PM
From past experiance on the 8 series, once you drop the version down, enable Air Print, it stays enabled even if you move back up to the current version and is no longer an option in admin. E
rrrohan
11-01-2019, 01:35 AM
Bonjour was already enabled
rrrohan
11-01-2019, 04:34 AM
winner winner chicken dinner
Must just be a firmware bug but least you got it working for me. thanks.
