View Full Version : Bizhub 35C-4 ?
mrfuser
10-31-2019, 08:26 PM
Anyone know what this machine is? Client brought from another location and it has no labels anywhere and the print outs only say 35C-4
is it a c353? C253?
allan
10-31-2019, 08:48 PM
Now this is where a picture will help.
mrfuser
10-31-2019, 09:16 PM
OK picture of what it looks identical to a C3 53 but many machines of that year age do
if there is a specific picture that you need to look at that will tell you exactly what it is tell me and I will take that picture
so there is no label on back that shows the serial # or machine id, can you print out a configuration page and see if machine model is listed there.
allan
10-31-2019, 09:48 PM
Then its a no-name rebrand. The serial number will give away the model.
Throw some firmware at it...
copyman
10-31-2019, 10:10 PM
That's weird, it looks like an NEC model # but the C353 is IT35 C5. I've never seen a 35 C4 and no where on my cross reference lists. Does it have IT in front of #'s. Like the other poster said post a picture and we will figure it out.
I'm sure most here know NEC designed the C253 and other color models. And Konica stuck with B&W. Not sure about now but back then NEC was making K/M color boxes.
mrfuser
10-31-2019, 11:36 PM
List print says serial number is 8030108
allan
11-01-2019, 05:38 AM
Yes that can be changed. Look for a serial number on the body.
copyman
11-01-2019, 01:59 PM
If you really want to solve the mystery post a picture! All I would need to see are a pic of front with door open & side door open
907tec
11-01-2019, 11:23 PM
Think it might be an Oce / Imagistics CM3522 (BH C353 cross). I have one out in the field somewhere, still.
KMFLT3CH
11-05-2019, 01:04 PM
If you print out a config page it should say Generic 35C-4, which is a C353. You probably have the "planets" screen when booting up the machine, too. This is an easy fix:
1. Access the Service Mode.
2. Select System 2.
3. Select Software Switch Setting.
4. Enter Switch No. "10".
5. Bin Assignment "00000000".
6. Hex Assignment "02".
7. Click on Fix.
8. Click on End.
9. Power the MFP OFF/ON.
10. Print another Configuration Page. Page Header should now be changed to Konica Minolta.
Generic 20C-4 = C203
Generic 22C-1 = C220
Generic 25C-1 = C250
Generic 25C-4 = C253
Generic 28C-1 = C280
Generic 35C-3 = C352
Generic 35C-4 = C353
Generic 36C-1 = C360
Generic 35C-1 = C450
Generic 45C-2 = C451
Generic 45C-1 = C550
Generic 50C-1 = C650
