View Full Version : Bizhube 554e belt
Apach
11-05-2019, 05:12 PM
Hi,
Can the Transfer Belt assembly of c554 fit into the 554e?
If can't maybe someone can give me a part number.
Tnx
copyman
11-05-2019, 05:25 PM
I thought the B&W and color were the same but after looking at part #'s it shows exclusive to the B&W 454e & 554e NOT color units. Learn something everyday. Probably would of known this but I have been rebuilding the trans belt units the last few years with new aftermarket belt & blade for under $100.
454e & 554e transfer belt part # A61DR70022D
allan
11-05-2019, 05:50 PM
If the belt is the same lenght and the blade the same then you could build that over if you really want to take that risk.
Best way is to try and shove it in there, would wonder if the retraction part for the color would be in the way...
tech51
11-05-2019, 05:55 PM
Seen them fitted before (by mistake) & they work ok but they’re probably more expensive than the mono ones.
tsbservice
11-05-2019, 06:38 PM
Hi,
Tnx
I would be more interested in opposite exchange ;)
For bizhub 554e part is:
Intermediate ImageTransfer Unit - A61DR71311
Albonline
11-05-2019, 08:35 PM
nope ,no color rollers or the retraction system on the mono unit.
Toxic
11-05-2019, 08:44 PM
It makes sense...
It is propably everything the same, just missing color rollers on bw type of transfer belt :)
larweedad
11-05-2019, 09:04 PM
A color belt on a BW copier. I have done that without thinking. The copier still worked fine. The BW models do not have the color transfer rollers and now sensor lever for them. Just cost more the color.
tsbservice
11-05-2019, 09:42 PM
O well stupid me :o
Belt only removed and cleaning section?
Walterj
11-07-2019, 06:20 PM
Hi,
Tnx
good day
The transfer belt of a C554 color equipment has 4 rollers of 1st transfer one for each color
Monochrome 554e only has a 1st transfer roller
Regards.
AL parts
11-09-2019, 02:05 AM
The transfer belt of the C554 and 554E is the same, and the Transfer Belt Cleaning Blade is the same.
This transfer belt is also compatible with many models, C226/256/266, C227/287, C258/308/368, C458/558/658.
