View Full Version : xerox d110 manuel
Apouthe Donald
11-06-2019, 10:47 AM
hello i have a xerox d110 which displays 042-312.
-I need your help and also need documentation.
here are the different works to realize
1-I replaced the AC ventilator
2-I replaced the engine Drum
3-I replaced fuser exhaust fan / fan transfer and fan intake fan.
after all this the code 042-312 is still present. thank you and need your helpers
adriansto
11-10-2019, 08:12 AM
I have it in edoc and pdf format.
My mail = stoadis@gmail.com
gpoffmachs
12-19-2019, 08:50 PM
BSD 9.13 (pws://file/xerox/edoc/95-110-125/chtml/svc.mhg.0000107927Fig13.htm#svc.mhg.0000107954) (D95/D110/D125 Only), BSD 9.13A (pws://file/xerox/edoc/95-110-125/chtml/svc.mhg.0000107927Fig14.htm#svc.mhg.0000225081) (D136 Only)
pws://file/xerox/edoc/95-110-125/icons/arrwup.gifDescriptionFail line is to be monitored every 500 milliseconds while ‘NVM 741-045 CleanerIntakeFanFailCycleTime’ from the Cleaner Intake Fan is ON. Then, a failure occurs when stop signal was detected ‘NVM 741-046 CleanerIntakeFanFailTH’ or more. (D95/D110/D125 ONLY)
Fail line is to be monitored every 500 milliseconds while ‘NVM 741-050 CleanerIntakeFanFailCycleTime’ from the Cleaner Intake Fan is ON. Then, a failure occurs when stop signal was detected ‘NVM 741-051 CleanerIntakeFanFailTH’ or more. (D136 ONLY)
pws://file/xerox/edoc/95-110-125/icons/arrwup.gif Procedurepws://file/xerox/edoc/95-110-125/icons/caution.gifCAUTIONThe Accessories have their own power cord. Whenever a procedure states to Power Off and then Power On, POPO, etc., powering Off and then powering On the IOT does NOT Power Off the Accessories. The Accessories will have to be Powered Off and then On separately from the IOT by unplugging the Accessory power cord.
Check the following:
Wire Harness BSD 9.13 (pws://file/xerox/edoc/95-110-125/chtml/svc.mhg.0000107927Fig13.htm#svc.mhg.0000107954) (D95/D110/D125), BSD 9.13A (pws://file/xerox/edoc/95-110-125/chtml/svc.mhg.0000107927Fig14.htm#svc.mhg.0000225081) (D136)
Cleaner Intake Fan ( PL 3.1 (pws://file/xerox/edoc/95-110-125/chtml/svc.mhg.PL3.1.htm))
no bulletins on this code
Apouthe Donald
12-20-2019, 08:43 AM
Thank you very much for the help, the machine works well. I would like to know:
1-you are in which country?
2-are you selling xerox equipment
here is my email: fredonaldy@gmail.com and my whatssap number 0022558549509
adriansto
12-20-2019, 06:26 PM
Check fuse F11 on IOT pwb
VINCENT23OMAN
09-27-2023, 08:50 AM
hello and good day, im having the same issue in my Xerox D125 error code 042-312, I check the back of the machine and all the harness but there is no tagging or marking on the harness. I couldnt locate where is the wire harness BSD9.13
adriansto
09-27-2023, 01:34 PM
BSD 9.13 is the schematics I posted in #11 on your open thread. On this schematics you see the connectors numbers and wires. If you cant manage to use this then place a call to xerox tech.
VINCENT23OMAN
10-03-2023, 08:51 AM
found the harness and tried to disconnect it from the board and recon and tried to on the machine. Still error is there. Maybe the board is defective
