View Full Version : PF-707
allan
11-07-2019, 09:53 AM
Hi guys sorry for the bother.
Need a part number for the PS40 centering sensor for a PF-707.
This unit was installed as a second PF for a C1100 but now need to use it on another machine.
Would that be a kit that needs to be ordered?
blackcat4866
11-07-2019, 07:05 PM
hmmm...
I never had tandem PF707s. I'll be interested in the answer. =^..^=
Toxic
11-07-2019, 08:46 PM
I think this is what you search for...
A50UM55100 (A50UM55111 new ) Compensating Sensor
tsbservice
11-07-2019, 09:31 PM
Now that one alone, if it works, would deserve another rep power ☝
Toxic
11-07-2019, 09:51 PM
We will see :)
And btw who gives/judge rep. power points,status... ?
Synthohol
11-07-2019, 10:46 PM
There is a star icon on the bottom left of every post.
If you feel the member has give accurate or helpful info you can click on it and rate that member.
blackcat4866
11-07-2019, 11:43 PM
It looks like a sheriff's badge, lower right of the specific post. =^..^=
Toxic
11-07-2019, 11:50 PM
Found it,never pay attention before on that simbol.
So Allan is that it?
allan
11-07-2019, 11:54 PM
Thank you.
Hope that would be available to me here.
Will check and let you know.
Christian_W
11-10-2019, 07:29 PM
Hi Allan,
in my opinion, there is no PS40 in the PF-707.
The PF-707 is the Paper Feed Unit from C1100, C2070 and newer Series.
Both Series have a Sensor inside the print system.
Christian
Toxic
11-10-2019, 07:53 PM
Hi Allan,
Christian
43988
allan
11-10-2019, 08:27 PM
Will take 3 to 4 weeks to get it here.
It comes with the PF but this one was never installed as a primary PF and the sensor assy since have been lost in transport...
My friend needs this machine installed at a customer without that the machine is a brick.
Error code C-5109 pops up if the sensor is not there.
Christian_W
11-11-2019, 04:49 PM
Sorry, you are right.
I found the partnumber in the parts catalog page 120 (acessory parts)
A5AWR73500 Deflection Sensor Assy
43992
reckless
11-04-2021, 07:20 AM
I have PF-707m hooked up to C6100. I am getting same error code : Error code C-5109
I don't see the sensor inside my brand new PF-707m. Is it needed for C6100?
reckless
11-07-2021, 01:44 AM
43988
It says only for C1100 series does anyone know if this is needed for C6100?
konicavod
11-09-2021, 07:54 PM
PF-707m Paper Feeder Unit
INSTALLATION MANUAL
https://i.ibb.co/cxrPK7d/2021-11-09-224940.png (https://imgbb.com/)
https://i.ibb.co/cYBjP8V/2021-11-09-225026.png (https://imgbb.com/)
lucky13
11-29-2021, 03:26 AM
yes its needed it comes with the c6100 bundled accessory pack its part # is also in the c6100 parts manual under accessory parts
