ECA
11-08-2019, 10:05 AM
Hi guys
after pulling my hair out on setting up a SMB scan folder on our new domain (server 2019, and freenas).
turns out the workgroup needs to be set as the domain name inorder for the bizhub to do the correct AD user auth.
e.g
SMB settings > Print settings > workgroup. set to XYZ (in caps). if for example the domain is xyz.local
anyway, after endless "server connection failed" errors later.
I realised the SMB the printer was using was version 1! FFS
Is there any firmware updates to upgrade to v2 or v3?
rom verison below
MFP Controller BOOT Program
A0P00Y0-1E00-G00-02(00)
MFP Controller SubSet
A0P00Y0-1F00-G00-12(00)
MFP Controller
A0P00Y0-0100-G00-C2(00)
Operation Panel Message Data
A0P00Y0-8100-G00-C2-00
Fax Board Controller1
15LA-0040-G02-13-000(00)
Fax Board Controller2
Scanner
A0P00Y0-0023-G00-82
Printer
A0P00Y0-0050-G00-15
ADF
A0HT0Y0-0024-G00-04
Finisher
A0HR0Y0-0071-G01-05
Panel CPU
A0P00Y0-8900-G01-01
DSC1
DSC2
Loadable Device Driver
SD
Voice Data
Movie Data
A0P00Y0-A000-G00-04
Dictionary Data
A0ED0Y0-B000-G00-0000
OCR Library
MFP Controller System
A0P00Y0-1000-G00-C2(00)
MFP Controller Print Controller
A0P00Y0-3000-G00-96
MFP Controller Print Controller Font
A0P00Y0-3F00-G00-21
MFP Controller Print Controller Demo Page
A0P00Y0-3E00-G00-01
MFP Controller MIO
A0P00Y0-5000-G00-23(00)
MFP Controller PSWC
A0P00Y0-5100-G00-20(00)
MFP Controller MIB IF
A0P00Y0-5200-G00-10
MFP Controller IPP IF
A0P00Y0-5300-G00-10
MFP Controller Outside Controller IF
MFP Controller TCP/Socket
A0P00Y0-6300-G00-21(00)
MFP Controller OPEN API
A0P00Y0-7000-G00-13(00)
MFP Controller Operation Panel
A0P00Y0-8000-G00-C2(00)
MFP Controller CSRC Control Body
A0P00Y0-8300-G00-02(00)
MFP Controller PIC
A0P00Y0-8200-G00-A0
e.g
rom verison below
MFP Controller
Scanner
A0P00Y0-0023-G00-82
Printer
A0P00Y0-0050-G00-15
ADF
A0HT0Y0-0024-G00-04
Finisher
A0HR0Y0-0071-G01-05
Panel CPU
A0P00Y0-8900-G01-01
DSC1
DSC2
SD
Voice Data
Movie Data
A0P00Y0-A000-G00-04
Dictionary Data
OCR Library
A0P00Y0-3000-G00-96
A0P00Y0-3F00-G00-21
A0P00Y0-3E00-G00-01
MFP Controller MIO
MFP Controller PSWC
A0P00Y0-5200-G00-10
A0P00Y0-5300-G00-10
MFP Controller PIC
A0P00Y0-8200-G00-A0
