View Full Version : C759 C659 thin lines on color IU at 60 K - 90 K
Norwaytech
11-11-2019, 12:26 PM
Hi, is there someone else that has got IU 712 M/C/Y that has not reach more than 30 -50 % life?
I have 2 different machines with that issues so far.
loks like there is some toner on the charge cl . and a very thin line on the drum..
Just wondering that I am alone, and is there anything to do ?
MVPunisher
11-15-2019, 01:41 PM
I also have 2 different machines that fairly consistently have IUs fail early for thin lines.
blackcat4866
11-16-2019, 03:44 AM
I can't explain why, but it's usually cyan that fails early. =^..^=
methogod
11-16-2019, 11:17 PM
off topic, but why did konica go back to IU in the CX59 series vs the CX58 series with DV units and separate drums for all colors?
EarthKmTech
11-19-2019, 07:01 AM
What is the page coverage like?
We have tons of c659-c759 in the field.
It’s a roll of the dice for when the lines start but for us it’s usually pretty close to end of life anyway.
EarthKmTech
11-19-2019, 07:03 AM
Because the c759 is just the continued evolution of a specific engine that started out as a CF2001.
The smaller separate drum and dev engines are an evolution of the old c360 series.
methogod
11-19-2019, 07:37 AM
looking for either as a backup machine, mainly for scanning but light production, i like the split dv and drum units as drums fail before DV units.
what are you thoughts on reliability and lower cost to operate?
uedele
12-01-2019, 11:22 PM
So i have just heard that there is a new wastebox come out for this model which helps with waste flow that will sort the I/U backing up pre maturely.
habik
12-03-2019, 10:27 PM
So i have just heard that there is a new wastebox come out for this model which helps with waste flow that will sort the I/U backing up pre maturely.You are correct. There is a new waste box type with modified inside spacers/ columns to improve waste toner flow. It will have a small round plastic nip on the back side distinguish from the old box.
There is a tech. bulletin about it.
Sent from portable device using fast cheapset!
Phil B.
12-03-2019, 11:19 PM
There is a tech. bulletin about it. Sent from portable device using fast cheapset!
please post bulletin?
