View Full Version : BIZHUB C6500 loading paper askew
arturceglowski
11-15-2019, 05:50 PM
Hallo,
I have two problems. I cannot set the skew and the paper is loading askew.
Attach image print patern no 16. Please help.
44054
Phil B.
11-15-2019, 06:18 PM
Hallo,
44054
well ok....
what tray is it feed from?
what type/size paper?
do size/type match on copier?
are the guides tight on paper?
how many pages on machine?
what have you done to correct issue?
personal or customer machine?
are you a tech or end user?
PhilB. "The Dentist"
arturceglowski
11-15-2019, 08:08 PM
well ok....
bypass
offset 90g 320x450mm
testy
yes
bw 678467
color1246895
service print adjustment
fd+cd mag. cs skew test print add as image attachnent
check adu rollers an cleaning
customer bizhub c6500 pro
low tech;)
Toxic
11-15-2019, 11:53 PM
Is it happens on all paper sizes and all trays or just that combination you already quote?
Did you try to clean registration roller?
arturceglowski
11-16-2019, 02:00 PM
Yes it happens on all paper sizes and all trays.
If you mean A03UR7C100, yes i clean this roller. I removed the whole section and checked it manually, the paper moves straight.
methogod
11-16-2019, 05:24 PM
loop adjust?
arturceglowski
11-18-2019, 10:09 AM
loop adjust?
I did the test again. Paper rotation unchanged by 2 mm
44065
methogod
11-18-2019, 08:56 PM
what size is the paper you are testing?
i would check this...
Dropbox - REGISTRATION_UNIT_ADJUSTMENT.pdf - Simplify your life (https://www.dropbox.com/s/mzb33oat4qd6dfp/registration_unit_adjustment.pdf?dl=0)
easy to mis-align.
arturceglowski
11-19-2019, 11:16 AM
easy to mis-align.
difficult to ..... :)
44079
Any other idea?
methogod
11-20-2019, 07:31 AM
44079
Any other idea?
what did you replace on the reg unit?
i would take it back part and reinstall, something must be off...
there are springs that have to be clocked correctly.
run the test print on differnt stock? maybe bad paper?
run the test on 8.5x11 or A4 short edge first..
run the test on card stock (A4 AND A3)
looking to isolate the issue...
SEE WHAT GIVES...
I HAVE A USED GOOD REG UNIT IF YOU WANT TO BUY IT.
