View Full Version : set time of a bizhub 450
gdu
10-22-2008, 06:57 AM
i would like to set the time of a bizhub 450. perfect would be a solution with net time use ip, could not make it work and cant find the menu option of the printer to change the time...
hope it is not an already asked question, search function didnīt helped me.
Mit freundlichem Gruss
Gert
lmt1979
11-19-2008, 04:36 PM
to change the time you just need to enter into Administrator mode
something like User Tools, Admin Mode
the default password is either 12345678 or all 0's (zeroes)
then, just look for timer settings.
gdu
11-19-2008, 09:40 PM
thank you a lot, worked great :)
HS_Gal
03-17-2009, 03:04 PM
Our office has the BizHub 253 and after the time changed for daylight saving the fax was off by an hour.
To fix it we pushed the Utility/Counter button
Selected Administrator Settings
Used the password 12345678
went to system settings and there was a Daylight Saving function we switch on.
This is also where you would change the time.:)
